Moen has the TL2368EP Remodel plate with handle that lets you change out a shower valve in the wall. It comes in pretty handy for replacing a broken or worn valve.
Here is an old Delta valve that somebody tried to change a cartridge on. Not so lucky I guess.
Using the supplied template, we drew a line on the wall surface and cut some of the shower wall out.
Here I have a Moen Posi-Temp with stops. I remove the stops and the cartridige while soldering.
Then the cartridge and stop are reinstalled.
Comparing the old Delta plate to the new Moen remodel plate.
And the finished work with the new valve and shower head.
Dope looking!
Moen TL2368EP with Posi-Temp
Dope looking!
