moen spout spigot 91194
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by 2td, Jan 24, 2013.
  1. 2td
    2td New Member
    Jan 24, 2013
    Bartlett Iowa
    This model leaks @ the hose to the stem, & is fixed by replacing the washers (guts) by screwing on a LP gas nipple at the stem base..A longer than stock hose has enough flex the pivoting parts are not needed... The threads are close (not perfect) so gently torque.. This is a one time deal so I used Through the Roof clear seal haveing a better bond as silicone or tape on the threads...This classic is so worth saving over the current:: plastic body/ junk valve can't beat brass.. Tom
Similar Threads: moen spout
Plumbing Forum, Professional & DIY Advice Moen wall mounted bathroom faucet spout with insufficient length Dec 25, 2014
Plumbing Forum, Professional & DIY Advice Removing Moen tub spout Oct 16, 2014
Plumbing Forum, Professional & DIY Advice Squealing Moen Tub Spout or Shower Valve Mar 22, 2011
Plumbing Forum, Professional & DIY Advice Moen tub spout leaks? Apr 12, 2010
Plumbing Forum, Professional & DIY Advice Moen kitchen faucet spout Aug 28, 2005
