Moen single handle tub/shower valve
Discussion in 'Shower & Bathtub Forum & Blog' started by marichpt, Oct 30, 2005.
  1. marichpt
    marichpt New Member
    Jul 30, 2005
    The single handle faucet does not have a push/pull feature (Chateau Posi-Temp, I think). There is no cold water coming from the tub or the shower although the sink does have cold water. After reading the Moen info sheets online, I suspect it is the balance spool at the back of the cartridge which has become stuck or blocked. I was able to remove everything per the disassembly instructions until the last instruction which said, "rotate cartridge shell between the eleven and one o'clock position, grast the cartridge stem with pliers and pull out cartridge." Question #1, Where is the cartridge "shell"? The exploded picture does not reference a "shell" and #2 how hard does one need to pull? I tugged pretty good but did not want to do damage. #3 What are the chances of cleaning and replacing rather than putting in a new cartridge? The system is less than 5 years old.
  2. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    moen products
    sometimes you really got to tug on those moen parts
    I have changed themout before risking pullling the damn thing
    right out of the tile wall....
    they make a puller too
  4. jimbo
    jimbo Plumber
    The shell is the plastic body of the cartridge. The stem is the chrome plated piece in the middle, the piece the handle screw goes into.
    If you can get it out, there is a rebuild kit.
  5. hj
    Moen
    I have had more success just tapping the cartridge on the floor a couple of times to get the spool loosened up. You will hear, or feel, it moving when you shake it if it comes loose.
    [​IMG]
Similar Threads: Moen single
Shower & Bathtub Forum & Blog Moen Posi-Temp, replacing cartridge of bathtub faucet single handle Sep 26, 2016
Shower & Bathtub Forum & Blog Moen single handle shower is slow to fully start and slow to stop Dec 28, 2015
Shower & Bathtub Forum & Blog Increasing the flow rate of a Moen Voss Voss-Single-Handle-High-Arc-Lavatory-Faucet Sep 27, 2013
Shower & Bathtub Forum & Blog Alignment of Moen plaster ground (single handed shower faucet) Apr 30, 2013
Shower & Bathtub Forum & Blog Hot/Cold Reversed on Moen Single Handle Shower Knob Apr 15, 2012
