Moen shower valve moans
Discussion in 'Shower & Bathtub Forum & Blog' started by ahosh, Feb 9, 2012.
  1. ahosh
    ahosh New Member
    Feb 9, 2012
    Westchester, NY
    Hey Guys,
    I have a Moen shower valve in my home's main bathroom. I am currently renovating my master bathroom and to re-run soem plumbing and rough in the new shower valve, I had to turn the main house valve on and off a few times. Now the Moen shower valve in the main bathroom moans when I move the lever to the hot side. It is a single handle and it seems to make the moaning noise anywhere along the warm water side.
    Any ideas why or what I can do to fix it?
    Andrew
  2. JerryR
    JerryR Member
    Jul 27, 2011
    Florida
    Call Moen at 1-800-289-6636 Describe the problem to them and they will send you a free replacement cartridge kit.
    Just had same problem.
    Jerry
  4. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    Good answer Jerry!
    JW
  5. hj
    The problem with that answer is that if it is a Moentrol valve the noise could be in the pressure balancing spool and a new stem will not cure it.
  6. JerryR
    JerryR Member
    Jul 27, 2011
    Florida
    I just got around to replacing my Cartrige. Last week I attempted to break it free with the plastic "tool" included in the kit. No way would it budge. I called Moen and they sold me the REAL TOOL for $25 and shipped it FedEx.
    I sprayed the old Cartrige with some PB Blaster 2 days ago. Tonight, With the REAL TOOL it came out. That tool works like a bearing puller where you can apply pulling pressure and at the same time slightly twist the cart. That did the trick.
  7. JerryR
    JerryR Member
    Jul 27, 2011
    Florida
    Mine was a positemp from 2001.
Similar Threads: Moen shower
Shower & Bathtub Forum & Blog Moen Chateau, Which shower trim fits this valve? Thursday at 6:57 PM
Shower & Bathtub Forum & Blog Moen shower valve issue when water heater drained. Jan 13, 2017
Shower & Bathtub Forum & Blog Help with removing Moen shower handle hub Nov 27, 2016
Shower & Bathtub Forum & Blog Moen Moenique, Help with shower faucet Aug 12, 2016
Shower & Bathtub Forum & Blog Moentrol, Only hot water coming from Moen shower Aug 11, 2016
