MOEN Shower Faucet Cartridge Replacement Issues
Discussion in 'Shower & Bathtub Forum & Blog' started by caldwelltim, Mar 26, 2008.
  1. caldwelltim
    caldwelltim New Member
    Mar 26, 2008
    Last night I removed the cartridge from my shower faucet and replaced it with a new one from home depot. When I turned the water back on, I was getting very little water out of the shower head and it sounded like a lot of air was coming out ... I then pulled the cartridge back out and one of the gaskets was broken. So I went back to home depot and got a new one. The air problem still exists, I haven't taken out the cartridge yet to see if the gasket is broken again. Any suggestions?
  2. hj
    gasket
    A broken "O" ring would cause a leak, keep it from shutting off, or mix the hot and cold water, but not prevent water flow. You must have a different problem, but we would have to know the faucet's model number to try to diagnose it.
  4. krow
    krow Plumber
    Feb 11, 2008
    Ontario, Canada
    If its a pressure balancer, then the balancing spool is stuck and it won't allow water to pass through iether the hot or cold
  5. rombo
    rombo New Member
    Mar 30, 2008
    Ontario
    the balancing spool is a good possibility, what cartridge was it
    also did you get all of the old cartridge out the moen's love to tear apart when being removed something may still be stuck
Similar Threads: MOEN Shower
Shower & Bathtub Forum & Blog Moen Chateau, Which shower trim fits this valve? Mar 16, 2017
Shower & Bathtub Forum & Blog Moen shower valve issue when water heater drained. Jan 13, 2017
Shower & Bathtub Forum & Blog Help with removing Moen shower handle hub Nov 27, 2016
Shower & Bathtub Forum & Blog Moen Moenique, Help with shower faucet Aug 12, 2016
Shower & Bathtub Forum & Blog Moentrol, Only hot water coming from Moen shower Aug 11, 2016
