Moen shower faucet attachment - confusion!
Discussion in 'Shower & Bathtub Forum & Blog' started by loFreqncy, Aug 1, 2008.
  1. loFreqncy
    loFreqncy New Member
    Aug 1, 2008
    I'm almost finished tiling my new shower, now its time to attach the faucet.
    I have a new moen shower setup listed here:
    http://www.moen.com/browsecatalog/c...inish=5664&crow=1&details=product&sku=82248BN
    According to the instructions I should be able to do a "slip fit" or IPS connnection for the spout. I would like to do slip fit, I currently have a brass pex drop ear in the wall waiting for me to attach pipe to it.
    The very vague:confused: instructions show a set screw attachment which is all well and good, but there is no place to put a screw at all. Just a U shaped cut out on the bottom of the spout, with nothing behind it. There is of course a threaded portion at the opposite end of the spout for IPS. Do I need a different spout all together? There seems to be nothing on the package to indicate a seperate IPS or Slipfit version. I thought I could do either with this kit. Thanks in advance for setting a newbie like me straight.
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    I'm sorry to hear about that! When you finish your job water will come out of both the spout and the shower at the same time. Pex is not supposed to be used in that application.
    :eek:
  4. jadnashua
    They have different part numbers for the slip-fit verses the IPS version of the spout...so, it appears they are not dual-purpose. Sounds like you got the 3806 spout verses the 3807. Probably a different dash-number on the box.
  5. loFreqncy
    Aug 1, 2008
    So far so good as far as I can tell, I've had the drop ear plugged and used the shower serveral times. Why would Pex make water come from both? Is it a back pressure issue. I'd really like to understand why this would be? To be clear, the drop ear is PEX(already connected in wall) to 1/2" ips.
  6. loFreqncy
    Aug 1, 2008
    Darn, looks like IPS it is, I don't want to waste any cash on this. Any tips on getting the ips pipe the perfect length? It says it should be 4 1/16" from the finished wall surface.
    Thanks again.
  7. Redwood
    Dec 15, 2007
    Service Plumber
    Wait until you try to use the spout to fill the tub!
    Due to the backpressure from using PEX it will come out of both the tub spout and the shower at the same time.
  8. Redwood
    Dec 15, 2007
    Service Plumber
    You will notice on the linked installation instructions for your valve on the top right side of page 2 in the Tub Shower dimensions drawing there is a small but very important note "Use 1/2†Copper or IPS Pipe Only." This is the very reason for that note.http://www.moen.com/shared/pdf/instruction_sheets/INS151F.pdf
  9. jadnashua
    The OD of pex and copper is the same, but the ID of pex is smaller, thus less volume and potentially more backpressure. Depends on your water pressure whether you'll see a problem. Pex to the valve would have been fine, but everything after the valve should be copper.
  10. loFreqncy
    Aug 1, 2008
    I did a test run, and it has a small trickle. still very usable, guess I'll have to live with it. If it really bothers me later on, I'll have to cap it off and tile over the spout. Thanks for the heads up. In the future I'll know better. Live and learn, I guess.
  11. B2CHR
    B2CHR New Member
    Jul 1, 2008
    Remodelng
    Central NC
    To me the inside of the pex seems to work fine but it's the very small dia of the 90 brass pex fitting that causes the restriction. I run pex up to the showerhead and this works fine to me.
  12. Redwood
    Dec 15, 2007
    Service Plumber
    Pex up to the showerhead is not a problem. Wnen you run it down to the spout the the small dia. of the adapter at the valve, tubing and drop ear 90, creates too much back pressure and pushes water up to the shower arm.
  13. loFreqncy
    Aug 1, 2008
    I am very happy to report that I encountered none of the above problems, works flawlessly. When I fill the tub, about 2 drops come out of the shower head at first, and thats it. You had me pretty worried!
  14. Redwood
    Dec 15, 2007
    Service Plumber
    Phew, You're a lucky one!
    If it happens at some time in the future it would probably be due to the water company increasing the pressure.
    In that case a Pressure Reducing Valve could be installed reducing the pressure to where it is now...
  15. hj
    Providence
    quote; I am very happy to report that I encountered none of the above problems, works flawlessly. When I fill the tub, about 2 drops come out of the shower head at first, and thats it.
    I guess there really is a Supreme Being who watches over people who do not read, or follow, the written directions.
Similar Threads: Moen shower
Shower & Bathtub Forum & Blog Moen shower valve issue when water heater drained. Jan 13, 2017
Shower & Bathtub Forum & Blog Help with removing Moen shower handle hub Nov 27, 2016
Shower & Bathtub Forum & Blog Moen Moenique, Help with shower faucet Aug 12, 2016
Shower & Bathtub Forum & Blog Moentrol, Only hot water coming from Moen shower Aug 11, 2016
Shower & Bathtub Forum & Blog 1969 Moen tub shower valve Aug 6, 2016
