Moen Posi-Temp....almost but not quite
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by das108, Mar 30, 2011.
  1. das108
    das108 New Member
    May 15, 2010
    DC
    Hi all.
    see picture attached of the installation of the cartridge. From other pictures I've seen here that is right.
    My problem is fitting together the key stop/limit stop/handle adapter properly.
    basically, just using the handle adapter it starts at 6 o'clock being off, going clockwise starts cold and moves to warm hot, stops when you get back to 6 o'clock
    However, using any combination of they key stop/temperature stop, the handle adapter, no matter where I orient things, will not do a proper rotation starting at off, rotating clockwise through cold to hot. It gets caught on the top notch of the stop tube key stop...its as if I am missing a piece that holds the keystop far enough out or something?
    thanks so much.
    C:\Documents and Settings\David\My Documents\Downloads IMG-20110330-00041.jpg
  2. Jerome2877
    Jerome2877 In the Trades
    Aug 25, 2009
    Vancouver Island , BC
    The cartridge is upside down, see the bottom H and C should be on top.
    [​IMG]
    Moen replacement 1222 for the Posi-Temp Shower Valve
  4. hj
    That only reverses the hot/cold orientation and would be proper for a valve with reversed piping. The clockwise operation is puzzling, since it should go from off to cold to hot with a counter clockwise rotation.
  5. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    And that is because the pipes aren't reversed but the cartridge is...
  6. das108
    das108 New Member
    May 15, 2010
    DC
    I'm 90% sure the piping is right on this setup.
    So to fix this, I pop out the safety pin/wire, remove the cartridge and re-insert rotated?
    I've heard some stories that these are very hard to remove without breaking/leaving something behind...any tips? (The Moen instructions are...not helpful...to say the least).
    Also, will this fix the issue with not seeming to be able to rotate enough without catching when all the pieces are in? or is that something separate.
    Thanks
    Davod
  7. jadnashua
    Probably will fix that. All newer valves have not only anti-scald functions, but also a max temperature limit arrangement which could be levers, stops, or whatever to limit rotation past some predetermined point. These are supposed to be adjusted when installed, and may need to be readjusted summer/winter if the incoming water temps vary (well, few, if any acutally do this, but you should!). Some of it depends on how hot you actually set your WH thermostat, but the difference in summer/winter cold water temps make setting the max outlet temp vary, so the adjustment needs to change (unless you buy the more expensive thermostatically controlled valve).
  8. das108
    das108 New Member
    May 15, 2010
    DC
    Yup. Was indeed that simple. Hardest part was getting the pin out because of the angle and size of the hole in the tile. Rotated it, put it back in, put everything back together, it all aligns properly and goes in the direction one would expect. Only casualty is a misplaced set screw for the faucet itself, which I imagine won't be too hard to get the right replacement for.
Similar Threads: Moen Posi-Tempalmost
Plumbing Forum, Professional & DIY Advice Moen Single Handle Pull Down Kitchen Faucet water supply hose question Feb 21, 2017
Plumbing Forum, Professional & DIY Advice Leaking Moen 7385 faucet need help Feb 9, 2017
Plumbing Forum, Professional & DIY Advice Moen Chateau knob replacement ? Feb 9, 2017
Plumbing Forum, Professional & DIY Advice Moen Shower cartridge Feb 2, 2017
Plumbing Forum, Professional & DIY Advice Moen shower head cold water only after shower remodel Jan 18, 2017
