Moen kitchen faucet - low flow problem
Dirtmover
Ontario
I've got a Moen kitchen faucet whose flow is a bit temperamental sometimes slowing to a trickle. I picked up a replacement 1225 cartridge assuming that there was some issue with it but alas this made no difference. I did however notice when the flow from the tap slows if I use the hand spray it works full force and the flow coming out of the tap actually increases at that point. When I stop using the hand spray the tap continues to flow at the normal flow rate. This fix is short lived however as over a period of time it will slow back down again.
What is going on with my faucet and how can I fix it.
Unscrew the aerator and clean the filter screen.
Dirtmover
Ontario
Yeah, should have mentioned the aerator is clear.
Supply pipes are 1/2" copper. Pressure is fine - well water 30/50psi.
All other faucets OK.
Behaviour is the same with full hot, full cold or half and half.
Dirtmover
Ontario
From the way the sprayer affects the flow, you have a defective diverter inside the faucet. Where it is, however, depends on which model you have.
Thanks, this is exactly the conclusion that I was coming to after doing a bit more reading this morning. I know exactly where it is. I popped it out yesterday and cleaned the scale off it and from the mating surface in the spout, greased the o-rings with silicone grease and put it back together. It looked fine but I've not figured out how this part works so I don't really know what to look for? What breaks with them and how do you tell if they're defective other than observing the symptoms? The only wear part I see is the o-rings.
JohnjH2o1
Florida
Replace it. In the mean time you can just leave it out. It will help your volume problem but it just won't turn the spout off when using the spray.
John
Dirtmover
Ontario
....but it just won't turn the spout off when using the spray.
No change there then. It doesn't turn the spout off anyway instead making the flow better out of the spout when the spray is on.
Thanks for the tip. If Home Depot don't stock it I'll just remove it until I get a chance to visit the local plumbing supply store.
As long as you know WHAT you need, call 1-800-BUY-MOEN and they will send you a replacement. I have NEVER had any luck cleaning or repairing diverters once they start to malfunction.
Dirtmover
Ontario
Thanks guys, my free warranty replacement diverter valve is on its way. I'm sure that will fix it.
