Moen Kitchen Faucet leak
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by bakechad, Feb 16, 2007.
  1. bakechad
    bakechad New Member
    Oct 31, 2005
    Illinois
    About a year ago I installed single handle pull-out Moen kitchen faucet. Overall it has worked well, but about three months after I installed it, a small amount of water would seep out of the area between the handle and faucet body when I turn the faucet on. Not enough to cause a major problem, but enough to leave water stains all over the faucet. The amount has steadily increased over time.
    Do you think this is most likely the cartridge or are there other seals in there that can fail? I know I need to disassemble it, but I would love to know what to look for before I take it apart. Also, if the parts I end up needing are cheap I would rather get them while I have the faucet apart rather than waiting for a warranty parts shipment.
    Thanks
    Chad
  2. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    Could be the cartridge or an o-ring on the swing spout.
    Take the handle off and pull out the cartridge's stem and watch.
  4. hj
    faucet
    It could be the vacuum breaker. If so, that part has been discontinued and if you call 1-800-BUYMOEN they will send you the parts to upgrade your faucet.
  5. Racer814
    Racer814 New Member
    Dec 24, 2006
    usually a faulty vacuum breaker will leak down through the valve body...but it could still be that....could also be the cartridge....call Moen and tell them to send you both....
  6. hj
    Moen
    The last one I repaired the lower "O" ring forced the water up out of the upper area.
Similar Threads: Moen Kitchen
Plumbing Forum, Professional & DIY Advice Confused about (old style?) Moen hydrolock leak under kitchen sink Jan 25, 2016
Plumbing Forum, Professional & DIY Advice How to take off cap and replace kitchen diverter - Moen Nov 23, 2015
Plumbing Forum, Professional & DIY Advice Problem with Moen kitchen diverter Nov 17, 2015
Plumbing Forum, Professional & DIY Advice Yet anther newbie question - Moen kitchen facuet drip repair Aug 6, 2015
Plumbing Forum, Professional & DIY Advice Troubleshoot Moen Faucet (Kitchen) Mar 9, 2015
