Moen handle problem!!
Discussion in 'Shower & Bathtub Forum & Blog' started by nards01, May 6, 2011.
  1. nards01
    nards01 New Member
    Feb 24, 2005
    Retired
    Washington County, PA
    I went to change a Moen cartridge and of course the 1st step is to remove the handle screw. Using a phillips screwdriver, I can turn the screw while holding the handle but it won't UNSCREW - it turns as apparently does what it's attached to. I have put pressure on the handle to help pull out the screw but no luck. I figure that I have to crack the plastic handle off??? I don't want to damage the screw neck of the cartridge that is in there so that my Moen removal tool will attach and remove it properly. Please HEEELP !!!! A 10 min job has turned into a nightmare. Thank you
  2. hj
    The handle must be broken already, so just cut it off.
  4. nards01
    nards01 New Member
    Feb 24, 2005
    Retired
    The handle isn't broken though. The screw just won't unscrew. But, if I do as you suggest what's the best way to "break" the handle off. Again, I want to be able to attach my Moen puller to the bad cartridge by screwing the puller into the "necK" of it. Isn't that what the handle is screwed into NOW??
  5. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    If the screw turns freely, it may be broken or the threads stripped. If this it the case, there is nothing other than gunk holding the the handle on.
  6. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    The handle is broken and the screw is spinning along with the center spindle of the cartridge.
    So yes bust out the handle so you can hold the spindle of the cartridge and prevent it from turning while you undo the screw to replace the handle.
  7. hj
    The handle IS broken internally, otherwise it would prevent the stem from turning when you twist the screw.
Similar Threads: Moen handle
Shower & Bathtub Forum & Blog Help with removing Moen shower handle hub Nov 27, 2016
Shower & Bathtub Forum & Blog Moen Posi-Temp, replacing cartridge of bathtub faucet single handle Sep 26, 2016
Shower & Bathtub Forum & Blog Moen Roman Tub Valve Handle Issue Jun 1, 2016
Shower & Bathtub Forum & Blog Moen Posi-Temp Banbury Model One Handle Tub/Shower Faucet - New install, hard to turn Feb 1, 2016
Shower & Bathtub Forum & Blog Moen single handle shower is slow to fully start and slow to stop Dec 28, 2015
