Moen Chateau cartridge replacement aftermath
Discussion in 'Shower & Bathtub Forum & Blog' started by loquin, Dec 6, 2007.
  1. loquin
    loquin New Member
    Dec 5, 2007
    An interesting issue.
    I replaced the cartridge on my moen shower valve. I went to Moen's website to get the cartridge number(s) for the Touch Control valve. (Note - this is the Touch Control Valve, Model # 82512, and NOT the chateau mentioned in the title, as it does NOT have the auto-balancing feature) I had no issues in getting the old cartridge out, or the new on in. (a while back, I shelled out for the cartridge replacement tool) However, there was one odd thing that resulted:
    After replacing the cartridge, HOT is now UP (rather than left) and the COLD is DOWN, instead of to the right !
    What in the world do I have to do to get it back to normal, with HOT on the left and COLD on the right? You can't just rotate the cartridge 90 degrees, as it won't work at all that way. And, if you rotate it 180 degrees, it just swaps the Hot/Cold.
    Thanks
    Lou
    Ref Model #85212 exploded parts view
    BTW - there were two cartridge numbers listed (1225 or 1200) - I tried them both - and had the same result...
  2. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    moen
    [​IMG]
    rotate the stem not the cartrage,180degrees and that should fix it.You ned to to take the handel off first there is a notch on the stem & should be on top.
    You do not have to take it out again just rotate the stem.You may want to turn water off but not neccesary.Let me know.
  4. jimbo
    jimbo Plumber
    cyhu2 is right on the money. These are designed for easy reversal, to handle back to back showers. Not necessary to even turn off the water main. Just put the handle in center ( straight up ) position. Remove the handle. With a small pliers, just rotate the stem 180º. Now put the handle back on.
  5. loquin
    loquin New Member
    Dec 5, 2007
    Thanks for the feedback, gentlemen. I'll give that a whirl.
Similar Threads: Moen Chateau
Shower & Bathtub Forum & Blog 90's Moen Chateau Shower Valve Jun 26, 2015
Shower & Bathtub Forum & Blog PLEASE HELP! Moen shower faucet help. Chateau, vs New/Old Legend. Apr 29, 2013
Shower & Bathtub Forum & Blog Nickel parts for Moen Chateau 6990 Roman Tub Trim Apr 14, 2010
Shower & Bathtub Forum & Blog Moen Chateau shower valve identity - dripping Oct 17, 2006
Shower & Bathtub Forum & Blog Garden Tub Moen Trim Replacement Jan 29, 2017
