Moen bathroom faucet cartridge replacing
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Hube, Feb 6, 2012.
  1. Hube
    Hube New Member
    Sep 1, 2004
    Ontario
    Our bathroom basin faucet knob is very hard {sticky} to pull up. There is a "cartridge" inside that can be removed and either replaced or cleaned of any gook accumulation. I have had no experience with these cartridges, so I'm asking whether its worth trying to replace or clean this cartridge, or just go and buy the whole complete faucet assembly. Thanks for any info.
  2. hj
    moen
    It is probably a brass core, and it is definitely cheaper to replace it than install a new faucet. But, whether YOU can do it depends on how tight it is stuck in the valve. I have six different tools to remove it, and sometimes it takes more than one to accomplish the task. IF you start hammering, chiseling, or drilling it, you WILL have to replace the entire valve. Call a good plumber who has the necessary tools to remove it. Once it is removed, there is absolutely no reason to reuse the old one.
  4. JerryR
    JerryR Member
    Jul 27, 2011
    Florida
    Moen has lifetime warranty. If you call them they will send you parts needed. When asked if you are the original purchaser say yes.
    They will also provide instructions on repair.
    Jerry
  5. Hube
    Hube New Member
    Sep 1, 2004
    Ontario
    Jerry, you were absolutely right!! I phoned Moen
    and they said they would sent out the new cartridge including the special tool to remove/install the cartridge. No charge to me at all. Thanks for your "heads-up'
  6. jimbo
    jimbo Plumber
    San Diego, CA
    The special tool they send is plastic. It breaks as soon as you try to turn it. We'll be waiting for your call!
Similar Threads: Moen bathroom
Plumbing Forum, Professional & DIY Advice Moen Monticello. Trying to Remove Bathroom Faucet Nov 26, 2016
Plumbing Forum, Professional & DIY Advice Bathroom Sink Faucets: American Standard vs Moen Vs Delta Apr 6, 2016
Plumbing Forum, Professional & DIY Advice Moen wall mounted bathroom faucet spout with insufficient length Dec 25, 2014
Plumbing Forum, Professional & DIY Advice Moen bathroom faucet ring shield Jan 12, 2009
Plumbing Forum, Professional & DIY Advice How to remove early 2000s Moen Shower Handle Mar 2, 2017
