Moen 87780SL leaking on cold side only
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Zaknefien66, Apr 20, 2007.
  1. Zaknefien66
    Zaknefien66 New Member
    Jul 26, 2006
    Hello all,
    I told a friend that I would post this question for her as I was already a member and could do it a lot easier for her. Any way she has a new MOEN Single Handle Kitchen Faucet with High-Arc Spout - Model #87780SL purchased from Lowes or HD, not sure which.
    When ever she turns on the cold water and turns it off it will drip. If she pushes the handle to the hot and turns it on and then off again, the drip stops. I am not familiar with this faucet, so I thought I would ask here to see if anyone has any suggestions.
    Thanks,
    Drew
  2. hj
    faucet
    She either needs a new cartridge, or the dripping water is draining out of the spout's "arc". Because of the aerator it could take a while for enough air to enter so that all the water in the outlet section could drain out. Turning it on and then off could create enough velocity, that the excess water is driven out.
  4. Zaknefien66
    Jul 26, 2006
    So would it be possible to take the aerator out and see if this stopped the drip? Seems like if it was a drain out of the spouts arc, it would do it on both sides and not just the cold side.
    Drew
Similar Threads: Moen 87780SL
Plumbing Forum, Professional & DIY Advice Moen Single Handle Pull Down Kitchen Faucet water supply hose question Tuesday at 6:03 AM
Plumbing Forum, Professional & DIY Advice Leaking Moen 7385 faucet need help Feb 9, 2017
Plumbing Forum, Professional & DIY Advice Moen Chateau knob replacement ? Feb 9, 2017
Plumbing Forum, Professional & DIY Advice Moen Shower cartridge Feb 2, 2017
Plumbing Forum, Professional & DIY Advice Moen shower head cold water only after shower remodel Jan 18, 2017
