Moen 3330 / 3320 valve instructions
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by teah2006, Mar 14, 2012.
  1. teah2006
    teah2006 New Member
    Mar 14, 2012
    TX
    I have the moen 3330 valve and the plaster plate was not set flush with my marble shower surround. My problem is the installers of marble surround threw away my plaster plate and I have no sure way of knowing the correct placement of valve. I need to know if someone can give some help. I have called moen and they are unable to give me any help. I tried to order face plate but they told me it would at least two weeks before they had any and I really need to get valve set before then if possible. I would appreciate it if someone could give some dimensions or other suggestions.
    [​IMG]
  2. Terry
    Aug 17, 2004
    There is some allowance in the valve. I would try installing your trim and see if it works as is.
    [​IMG]
    Parts breakdown
    [​IMG]
    This picture says thin wall but it gives you an idea of what is projecting from the finish wall too.
    [​IMG]
    The upper diverter
  4. jimbo
    jimbo Plumber
    San Diego, CA
    One way would be to install all the trim. Then if you know the composition of the finished wall..., e.g. 1/2 cement board, 1/4" tile, 1/16" mortar...that will take you back to the plane the valve should be mounted at. The plaster ground probably allows 5/8" wiggle room, but we do hear complaints from people if the valve is mounted too far out...they say the handles look funny. Too far IN, the handles will stick
  5. hj
    I think you have confused me. IF the marble is already set, then the valve's position should be fixed, and all you have to do is install the trim pieces. In fact, at this point, that may be ALL you can do. If the plaster ground was not flush with the marble, then it could be too shallow or too deep for your trim. If it is too shallow, you are out of luck, if it is too deep, you can get a 1" extension kit.
  6. teah2006
    teah2006 New Member
    Mar 14, 2012
    TX
    moen 3330 valve
    sorry I confused you. i have access from closet. If I had my plaster plate I could unsolder the valve and reposition the valve. my problem is that the company installing marble threw the plaster plate away. I didn't realize until it was too late. I thought maybe some one may be able to give advise on how to reposition the valve without the plaster plate.
  7. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Even with the plaster guard, it might not be where you want it. The distance the knobs stick out is much a matter of aesthetics and everyone has a different opinion as to how much is too much.
    If you REALLY want the plaster guard, go buy another valve and then return it when you are done.
  8. teah2006
    teah2006 New Member
    Mar 14, 2012
    TX
    thank you I may try the aesthetics and then if still not satisfied your idea on buying another valve and then returning the valve is a idea that i've never considered. I'll let you know how things work out. I'm open for any new ideas. Moen
  9. hj
    I am working on a job where another company installed the Moen valves then tossed the plaster guards. At that point they were useless anyway, except to make sure the tile company made the holes large enough. When I got there, it looked like they were installed too deep, so I tried the trim on the valves to see if they would fit. Most of them did, but one is marginal so I won't know if I will need an extension until the tile is finished. Install the trim and see if there is a problem.
  10. teah2006
    teah2006 New Member
    Mar 14, 2012
    TX
    I tried installing the trim and that's when I started looking at the way valve was installed. I couldn't fine trim plate and I called the company who installed marble. I talked to the installer and he informed me he had thrown it away at their shop. The garbage had been picked up the Friday afternoon they finished installation.
  11. jadnashua
    Unless you have a thinwall installation, once the valve's position is set, there's no reason to keep the plaster guard.
    As already said...if the trim will fit and tighten up, it should be okay (but you may not like the way it looks). If it sits too far into the wall, then you either need to move it forward or buy the extension kit (if one is available for that valve).
  12. hj
    quote; I couldn't fine trim plate and I called the company who installed marble. I talked to the installer and he informed me he had thrown it away at their shop.
    The trim plate is the chrome ring. If he threw it away he needs to get you a new one because it is part of the valve and you cannot finish it without the ring. You say you "tried installing the trim". What happened then? Did it, or did it not, fit. If not then I hope it is too deep in the wall so the installer can GIVE you the necessary extensions. If it is too shallow then the valve has to be moved. So far you have NOT told us anything about how the trim fits or if you have it all, so we cannot tell you what, if anything, you have to do.
Similar Threads: Moen 3330
Plumbing Forum, Professional & DIY Advice Moen rough in valve 3320 3330 Feb 8, 2010
Plumbing Forum, Professional & DIY Advice Moen L4621, odd leaking bathroom tap! Yesterday at 4:15 PM
Plumbing Forum, Professional & DIY Advice How to remove early 2000s Moen Shower Handle Mar 2, 2017
Plumbing Forum, Professional & DIY Advice Moen Single Handle Pull Down Kitchen Faucet water supply hose question Feb 21, 2017
Plumbing Forum, Professional & DIY Advice Leaking Moen 7385 faucet need help Feb 9, 2017
