Moen 1222 cartridge - plastic or brass shell?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by JerryR, Jul 18, 2014.
  1. JerryR
    JerryR Member
    Jul 27, 2011
    Florida
    I just swapped out a Moen 1222 positemp shower cartridge at my daughter's 10 year old house. The OEM Moen branded valve was standard plastic shell.
    I see that Moen sells a commercial version 1222HD which is brass shell. Is there a benefit or using one or the other?
    JR
  2. Terry
    Aug 17, 2004
    Since the moving part is brass anyway, sliding through rubber seals, I don't think so.
  4. asktom
    asktom Member
    Nov 9, 2009
    Victor, MT
    I agree with Terry but will add that the brass shell would be more apt to get corroded in place just as the 1200 cartridge is prone to do.
  5. hj
    The plastic ones can be hard enough to extract, I would not want to fight a corroded brass one to remove it.
  6. JerryR
    JerryR Member
    Jul 27, 2011
    Florida
    This was the 2nd Positemp cartridge I have replaced. Both lasted about 10 years. Without the special Moen tool I would not have been able to get the old ones out. The one today had one of the rubber seals folded over and it took pre-lube and lots of heavy pulling and twisting to extract it.
    I can see how a corroded brass one would have been worse.
    Thanks for the advice, I'll continue to use the OEM, Moen brand, plastic ones.
Similar Threads: Moen 1222
Plumbing Forum, Professional & DIY Advice Moen 1222 valve not working with hot water on demand heater Oct 1, 2013
Plumbing Forum, Professional & DIY Advice Moen L4621, odd leaking bathroom tap! Today at 4:15 PM
Plumbing Forum, Professional & DIY Advice How to remove early 2000s Moen Shower Handle Mar 2, 2017
Plumbing Forum, Professional & DIY Advice Moen Single Handle Pull Down Kitchen Faucet water supply hose question Feb 21, 2017
Plumbing Forum, Professional & DIY Advice Leaking Moen 7385 faucet need help Feb 9, 2017
