Modify drain line, maybe
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by carrud, Nov 16, 2013.
  1. carrud
    carrud DIY'er
    Apr 19, 2013
    Los Angeles area
    The 3" drain line from the 2nd floor runs down my shower wet wall. This is cramping me with my desire to center my new shower valve which uses a Grohe GrohFlex rough-in. This new one is much bigger than the original valve.
    Do I have any plausible options to, perhaps, add a couple soft bends to the 3" drain to offset it around the valve area and then bring it back to tie back into the location where it drops into the slab? Or any other idea?
    The valve needs to be to the left of the that drain line.
    The last pic shows approximate desired location in relation to the drain line.
    Many Thanks, Clark
    !!Drain from 2nd floor IMG_0549 copy.jpg !!Drain from 2nd floor IMG_0548 copy.jpg !!Drain from 2nd floor IMG_0550 copy.jpg
  2. bluebinky
    bluebinky Member
    Aug 31, 2011
    Software Engineer
    Santa Clara, CA
    Unless the room is really cramped, I would just fir out the wall behind the shower another inch or two.
  4. carrud
    carrud DIY'er
    Apr 19, 2013
    Los Angeles area
    Interesting option. I don't think taking a couple of inches works well in this room, but I'll give it proper consideration in the morning light. However, to me it seems a better option to be adjusting the drain if it seems reasonable. I'll think about this.
    Thanks for the response.
  5. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    Looks like 4 1/8th bends should offset it enough.
  6. Terry
    Aug 17, 2004
    I would remove the sagging rubber Fernco coupling above and replace withe a no-hup coupling. It needs the metal wrap to keep the pipe from sagging. Rubber doesn't support the weight of Cast Iron pipe.
    We can only use a coupling like that if it's fully supported in the ground.
    Not too many plumbers would consider offseting a cast iron stack to center up a shower valve. I've seen plenty of shower valves installed off center on purpose to make it more convenient. Centering the shower arm makes sense though.
  7. carrud
    carrud DIY'er
    Apr 19, 2013
    Los Angeles area
    Terry, thanks for catching and explaining about the sagging rubber Fernco.
Similar Threads: Modify drain
Plumbing Forum, Professional & DIY Advice Modifying cast iron drain to move toilet? Feb 1, 2014
Plumbing Forum, Professional & DIY Advice Need help modifying the basement toilet rough in Mar 5, 2016
Plumbing Forum, Professional & DIY Advice Modifying existing pipe Feb 10, 2009
Plumbing Forum, Professional & DIY Advice Modifying Plumbing / Soldering / Leaks ? May 16, 2008
Plumbing Forum, Professional & DIY Advice Modifying Bath Plumbing May 7, 2008
