Modified Home Run Pex Water Distribution System
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by poky1234, Feb 27, 2014.
  1. poky1234
    poky1234 New Member
    Dec 17, 2012
    Woodbridge Ontario
    Hello,
    Iam restoring a century home and I am replacing all the old plumbing system. I am trying to decide between a Home Run System or a Modified Home Run System. The house is 2 story. I want to use the Modified Home Run System and use sub manifolds. If I were to run to the second floor to supply a lav , toilet and tub could I use 1/2 inch pex to supply the sub manifold or would I have to go to 3/4? Town water pressure is around 45 lbs.
    Thanks,
    Doug
  2. wjcandee
    wjcandee Wise One
    Apr 27, 2012
    New York, NY
    Why are you focusing on saving 50 cents on the materials?
    Can I get away with half-assing the thing? Probably.
    Will it be as good as if I used the proper materials? Probably not.
    PS As you probably know, this pex stuff moves a lot less water per diameter than pipe like copper. So why not give the house a plumbing system that it can be proud of instead of trying to figure out the minimum that you can get away with?
  4. mikeplummer
    mikeplummer Plumber
    Mar 28, 2012
    Ontario, Canada
    you are in Ontario - so our plumbing code will dictate your minimum pipe size determined by supply fixture units, distance and service pressure. I always run 3/4" to a second story and branch 1/2" off it. I also use copper main runs
  5. Terry
    Aug 17, 2004
    The cold for a bathroom should be 3/4"
    You do add a toilet with that.
    Hot can be 1/2"
  6. poky1234
    poky1234 New Member
    Dec 17, 2012
    Woodbridge Ontario
    Thanks for the answer Terry and Mike.
Similar Threads: Modified Home
Plumbing Forum, Professional & DIY Advice Pex Modified Homerun System Design Jan 28, 2011
Plumbing Forum, Professional & DIY Advice Cleanout needs to be modified Jul 21, 2008
Plumbing Forum, Professional & DIY Advice Modified Washering machine drain...still overflows Sep 19, 2007
Plumbing Forum, Professional & DIY Advice p-trap or modified s-trap question Mar 1, 2007
Plumbing Forum, Professional & DIY Advice Dumb question: will a lateral vent prevent a backup event inside the home? Wednesday at 6:52 PM
