Model number for Drake bowl
Discussion in 'Toilet Forum discussions' started by Hobbes, Aug 2, 2008.
  1. Hobbes
    Hobbes New Member
    Jul 30, 2008
    Southern New Jersey
    I just ordered a Drake (CST744S in Cotton White) and the order lists two model numbers (for the bowl and tank). The tank is ST743S and the bowl is C744E. I thought I had previously seen the Drake bowl with a different letter at the end instead of the "E". I just want to verify that my order is correct for a standard Drake toilet.
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    What you ordered is the Drake toilet and tank. This is standard height (not ADA) with an elongated bowl. No seat is included.
  4. Hobbes
    Hobbes New Member
    Jul 30, 2008
    Southern New Jersey
    Good, that is what I wanted to order. I thought the part number for the bowl ended in an "S", not an "E", so I just wanted to check that it wasn't some other variation of the Drake.
    Thanks.
  5. Peanut9199
    Peanut9199 Customer Service Manager Plumbing Wholesale
    Apr 23, 2007
    Ontario, Canada
    Your correct the bowl does/did come with a S at the end of it.
    C744S S stands for "G-max" flush 1.6gpf
    C744E E stands for "E-max" flush 1.28gpf
    ST743S is the tank that has the G-max flush in it, either bowl will work.
    The most important is the tank if you want the G-Max flushing technology.
  6. Terry
    Aug 17, 2004
    Toto is switching the bowls over to E
    The E works with either tank.
    I haven't seen an S bowl for a while in the Drake line.
  7. Hobbes
    Hobbes New Member
    Jul 30, 2008
    Southern New Jersey
    Hmm, so I'm a bit confused by those two posts if I read correctly. Peanut says the E designation is for E-Max flush (1.28 gpf) and the S designation is for the G-Max flush (1.6 gpf). Terry appears to say the E is a new designation for the same old Drake bowl and either tank can be used.
    Is it the tank that determines the gpf and the bowl design hasn't changed? Or is the bowl also different between the two versions? I did not want to get the 1.28 gpf model.
  8. Terry
    Aug 17, 2004
    They don't make the S bowls anymore.
    The diffence is the tank.
    Those are either
    ST743S, 1.6 gallons
    ST743E, 1.28 gallons
  9. Hobbes
    Hobbes New Member
    Jul 30, 2008
    Southern New Jersey
    Okay, great. Thanks much for the clarification.
Similar Threads: Model number
Toilet Forum discussions Toto Ultramax II model numbers do not match Dec 30, 2016
Toilet Forum discussions Toto Drake II model number confusion Oct 27, 2016
Toilet Forum discussions Is there a place on Toto toilets where it says the model or gives a model number? Aug 5, 2012
Toilet Forum discussions Toto Drake Toilet Model number CST 744SL Oct 22, 2010
Toilet Forum discussions TOTO Model Numbers? Apr 6, 2010
