Darcy Roberts
My well had 4 galvanized tanks in parallel in a double tee formation, with a 1 1/2 inch water main out the bottom back of one of the tanks which services 4 houses. The tank with the main to the houses started leaking and I replaced it with a bladder tank. I now am getting air out of my faucets every time I open a faucet. None of the other houses are having this issue. My house is only 40 feet from the well the other 3 houses are several hundred feet and higher in elevation than my house. I am getting conflicting advice from local plumbers. One thinks the well pump is pumping air into the tanks and the bladder tank should not be having air going into the bladder. Another says I need to plumb the bladder tank "in back" of one of the galvanized tanks so the "air" is going into the galvanized tank and not into the bladder tank. And one says to replumb my houses water line so that is in front of the bladder tank. I have uploaded a picture of the plumbing for the 4 tanks. Thanks for helping me figure out why I am getting air in my lines but not my neighbors. PS... my picture would not upload, sorry
