Mixing Valve Problem?
Discussion in 'Tankless Water Heater Forum' started by monahanky, Feb 19, 2013.
  1. monahanky
    monahanky New Member
    Feb 19, 2013
    Boston
    Hi,
    I had an issue last week whereby my water was not enough. I got the mixing valve replaced and now I have the opposite problem where the water is almost boiling. I adjusted the mixing valve in the "colder" direction as far as possible but the water is still boiling. Is there something else I need to adjust to bring my water temperature to a more moderate temperature. Or is this just an issue with the mixing valve? Right now it is dangerous because it is so hot. I have a Weil McLain boiler.
    Thank you in advance.
    Mike
  2. Dana
    Dana In the trades
    Jan 14, 2009
    01609
    Is this a boiler with an embedded tankless coil, a sidearm water heater, or an indirect-fired HW tank?
    Is it possible that the new mixing valve was installed backwards? Valve manufacturer and model ==?
    Mixing valves would (almost) never be sold un-tested & defective right out of the box, but I suppose it's possible to screw up a sweat-soldered version during installation with solder splash.
Similar Threads: Mixing Valve
Tankless Water Heater Forum Mixing valve requirement Dec 3, 2015
Tankless Water Heater Forum Caleffi Thermostatic mixing valve problem solved on a TriangleTube Prestige system Dec 27, 2013
Tankless Water Heater Forum Takagi T-M1 unit has a small leak, at mixing valve? Apr 28, 2010
Tankless Water Heater Forum Maximum distance allowed away from unit for PRV valve? Feb 9, 2017
Tankless Water Heater Forum T&P valve required? Aug 27, 2015
