mixing the mud
Discussion in 'Shower & Bathtub Forum & Blog' started by dedalus, Apr 8, 2014.
  1. dedalus
    dedalus New Member
    Mar 23, 2014
    NSW
    Before I get cracking on my shower install I need some advice on mixing the mud. I was planning to use Laticrete 3701.
    My floor is 900 x 900 mm = 0.81 sq m.
    Laticrete 3701 specs say you get 0.3 m2 at 50 mm depth per bag. And since my depth at the drain lip will be 38mm, I'm figuring on an average depth of about 45 mm, give or take. That implies a maximum of 3 bags.
    I've mixed heaps of concrete but never any of this stuff. So 3 questions:
    1) Do I mix it all in one big batch? Or 3 seperate batches.
    2) How long do I have before the stuff goes too gooey to work. Laticrete say "pot time" is two hours. Does this mean I have to RUSH? No coffee break half way through, right?
    3) Can I mix it by hand? Or must I use a paddle gizmo on the end of my drill. How long would it take to mix 3 bags?
    Thanks.
  2. jadnashua
    Deck mud is mixed with a minimum of water. It should not flow, it's much closer to wet beach sand than any concrete or mortar you may have mixed. The goal is to get it so if you grab a handful of properly mixed stuff, when you squeeze it, it holds together but does NOT drip excess water. You can mix it by hand, and they make a special hoe for this - it has holes in it so it tends to mix things more than just moving them around like a solid hoe would.
    The stuff is cheap enough, that you could make yourself a trial pan. As with most things the second time is much easier and faster. I wouldn't get part done one day then try to finish the next, but if you need to mix some more, if what's there is still wet, you should be okay. You want to avoid cold joints which can happen if things have cured too much.
  4. Vegas_sparky
    Vegas_sparky Digital Billy
    Dec 5, 2013
    Electrician
    LV,NV/ Nowhere,UT
    It'll look damp/dark, but won't feel really wet. You won't think it has enough water, but it probably will.
    Like Jim said, its cheap. Make a small batch to get the feel of it. I've seen guys on the job leave a mixed wheelbarrow full for a couple hours. Use a hand tool to mix it(shovel or hoe).
  5. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
  6. jadnashua
    And, John, you've followed me around my whole life and know for certain that I've never mixed deckmud? You're the fool.
    Lots of people mix their deckmud with different cement/sand ratios. Especially for a conventional shower, you do NOT want it 'rich' or have very much cement in it. It needs to be porous. Most of the pros I've talked with say around 5:1 sand/cement is a good ratio for you mud. There may be times when you want it denser, but for a shower pan, that's good. The more water you use, the more likely any cement based install can shrink and crack. You need more water to pump it, and that's not a great consistency for a shower pan. If you were doing something like a mudbed for a tiled floor, you have more leeway.
    If you really have doubts, go read it from the source - you'll find it conforms to what I've posted. More of John being the jerk he is...personally, I'd not put up with it if I were one of his customers. Hope he treats them as adults and has some manners.
  7. dedalus
    dedalus New Member
    Mar 23, 2014
    NSW
    My question was specifically about Laticrete 3701. If anyone has mixed it I'd like to know if I can mix it by hand in a bucket, or do I need a paddle.
    Ordinary sand/cement mix I could obviously mix it any way which. I need to know if 3701 is HARDER to mix.
    Thanks guys.
  8. jadnashua
    I would not use that for a mudbed in a shower. There is no reason why you need a modified mudbed there, and it will likely be less porous. A modifier can make it sticker, and somewhat harder to shape. Plus, it costs more than a simple deck mud of just cement and sand.
    Because it is modified, to fully activate the dry polymers, you may need a paddle to adequately mix the stuff. Call their tech service line for advice.
  9. Vegas_sparky
    Dec 5, 2013
    Electrician
    LV,NV/ Nowhere,UT
    Daedalus, are you building a conventional shower pan with preslope/liner/mud bed, or will you cover it with something like Kerdi?
  10. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Jim - that would bore me. You live in your office pretending to be a builder. That is sad.
    Mixing mud in you sales class is not the same thing.
    Dedalus - did you email Arthur? He is one of the top techs at Laticrete. Super nice guy. Ask the man directly. God forbid you used anything other than sand and cement. Why would you? Jim says it's a waste of money....
    LOL
    Key Info from the post above....
    Retired Defense Engineer / Triple Schluter Workshop Graduate
    The Ditra Cheer
    [​IMG]
    Ditra's Number one Fan - Jadnashua (The Ditra Cheerleader)
  11. jadnashua
    And, how would you know, John...invasion of privacy is a crime, and assuming things is, well you know the saying, but it does describe you well.
Similar Threads: mixing
Shower & Bathtub Forum & Blog Is it possible to adjust this particular shower mixing valve? Jan 19, 2017
Shower & Bathtub Forum & Blog Shower mixing valve Jan 19, 2017
Shower & Bathtub Forum & Blog Best type of shower mixing valve / highrise bldg with poor pressure balance Dec 21, 2016
Shower & Bathtub Forum & Blog Kohler Niedecken, Need information on very old shower mixing valve Dec 8, 2015
Shower & Bathtub Forum & Blog Two questions about Delta shower mixing valve Oct 6, 2015
