Mixing materials in DWV
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by InspectorGadget, May 29, 2005.
  1. InspectorGadget
    InspectorGadget New Member
    Apr 10, 2005
    I know that it's not good practice to use dissimilar materials when soldering, cementing, or chemical welding.
    What about compression fittings?
    I have ABS in the wall for drainage. Can I use PVC from the bottom of the sink, as a p-trap, and then connect the PVC directly to the ABS with a compression fitting? Any long term problems associated with this?
    Steve
  2. jimbo
    jimbo Plumber
    If you mean using tubular fittings under the sink and connecting at the wall with a slip-joint adapter, this is very normal.
Similar Threads: Mixing materials
Plumbing Forum, Professional & DIY Advice Mixing SDR35 and ABS? Jan 5, 2017
Plumbing Forum, Professional & DIY Advice thermostatic mixing valve (Honeywell AM-1 1070) seized after <3 years? Jul 31, 2016
Plumbing Forum, Professional & DIY Advice Hot Water Backfeeding - Issue with Recirculating Pump and Mixing Valve Jul 7, 2016
Plumbing Forum, Professional & DIY Advice Space issue between mixing valve and tub spout Jun 29, 2016
Plumbing Forum, Professional & DIY Advice How would you remove the cartridge from this mixing valve? Jun 21, 2016
