Mixette Shower Control- low flow
Discussion in 'Shower & Bathtub Forum & Blog' started by shall, Jul 14, 2007.
  1. shall
    shall New Member
    Mar 23, 2007
    Sacramento
    I replaced the old Mixette valve with a new Mixette control a few months ago. There doesn't seem to be as much water flow when full open as there used to be. Is this the valve or what? Don't really want to tear out the wall again so maybe aother new valve?
    Stan:confused:
  2. jadnashua
    Take the showerhead off and see if there is anything clogging up the screen.
  4. shall
    shall New Member
    Mar 23, 2007
    Sacramento
    Mixette Valve -low flow
    :eek: Thank you Much. I forgot to say that I removed the shower head and then removed the low flow screen so there should be no restriction to the water. I am thinking that I didn't do something correctly when I replaced the valve cartridge.
    Stan
  5. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    Try removing the cartridge and re-installing it.
    If that doesn't work, you may need to get a different type of cartridge:
    http://www.nomix.com/
  6. shall
    shall New Member
    Mar 23, 2007
    Sacramento
    Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
  7. shall
    shall New Member
    Mar 23, 2007
    Sacramento
    OK___ that sounds really good. I will pull the cartridge out and check the operation and re-install. Good to know that there is a replacement available.
    Thank you for the response and possible solution.
    Stan
Similar Threads: Mixette Shower
Shower & Bathtub Forum & Blog Lustrolite shower wall covering Monday at 11:17 AM
Shower & Bathtub Forum & Blog Delta rain can shower head install Sunday at 7:12 AM
Shower & Bathtub Forum & Blog Cutting into block wall for shower water supply Feb 14, 2017
Shower & Bathtub Forum & Blog Concrete shower pan; do I need a liner? Feb 14, 2017
Shower & Bathtub Forum & Blog Shower Leak to basement... Feb 10, 2017
