Hi, folks, I hope you can help me with this problem. I'm sort of a plumbing novice.
I just installed a new bathroom vanity and sink. Apparently the centerline of the drain on the new sink is not the same as that on the old one. When I try to re-connect the p-trap to the existing j-shaped pipe protruding from the wall, I'm unable to make the connection because the outlet of the p-trap is about an inch away from the inlet of the existing wall pipe, so that one cannot reach the other.
How do you suggest I solve this? Do I have to remove the existing j-pipe and replace it with a longer one, if that's possible? Can I install some sort of flexible trap fitting that can bridge the gap? If the j-pipe coming out from the wall needs to be replaced, do I have to melt the solder to remove it or can it be cut off and the new one be somehow connected?
Thanks a ton for any advice on this.
harvey-p
harvey-p
