Minimum wall requirements
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by willl, Jul 3, 2008.
  1. willl
    willl New Member
    Jul 18, 2005
    North Dakota
    Hello everyone,
    I believe that 3" pipe drains the best for toilets right. My question is if I am to run the 3" drain pipe in a wall what is the minimum size the wall should be. 2 by 6 or 2 by 4.
    The wall where a shower head is located within. What size should this wall be at. 2 by 6 or 2 by 4. Thank you:D
  2. jimbo
    jimbo Plumber
    3" pipe is 3½" OD. The OD of any fitting sockets, couplings, etc. is nearly 4",so that does not work in a 2X4 wall. Any wet wall is easier to work with if you make it 2X6. Trying to mount a shower valve for proper reveal, in a 2x4 wall, can be tough, but it is doable. It was the norm in a lot of construction. I have seen house where they put the drains in 2x4 walls, and just let the drywall bow out where necessary. Not pretty.
  4. willl
    willl New Member
    Jul 18, 2005
    North Dakota
    OK, how about this question. If I have a room that is 4' by 5' with one toilet and one sink (probably one of those small pedestal sinks) and the toilet and sink are side by side where is the best place to put them side by side. Along the 4' wall or the 5' wall. Care to explain. Thanks
  5. hj
    size
    Given the code spacing requirements, the only way they fit properly is usually the 5' dimension.
Similar Threads: Minimum wall
Plumbing Forum, Professional & DIY Advice Minimum toilet vent size? Dec 11, 2016
Plumbing Forum, Professional & DIY Advice Minimum drop for toilet in basement Jul 8, 2016
Plumbing Forum, Professional & DIY Advice Minimum guest bath dim Jul 20, 2015
Plumbing Forum, Professional & DIY Advice Minimum Slope for 3" Waste Line Oct 28, 2014
Plumbing Forum, Professional & DIY Advice Minimum 'collar' for sweating pipe Dec 21, 2013
