Minimum vertical distance from tub bottom to p-Trap inlet?
Discussion in 'Shower & Bathtub Forum & Blog' started by bagdanoj, Oct 20, 2009.
  1. bagdanoj
    bagdanoj New Member
    Oct 16, 2009
    Portland,OR
    The title is the crux of my question, but here's more information if you need it:
    I am doing a bathroom remodel. The old bathtub (already removed) was installed on a 7-inch platform (also, already removed) in order to accomodate the drain plumbing that had to be installed above the floor (the inlet to the p-trap is about 3 inches above the subfloor and must stay that way). I am preparing to rebuild the platform to accomodate the new tub, and I was just told by a plumbing contractor's estimator that I will need to build the platform so that the bottom of the tub is a full 7 inches higher than the p-trap inlet (to accomodate the drain and overflow assembly, with sanitary tee and 3-inch tailpiece).
    But this doesn't seem right to me. The specs for the Kohler drain/overflow assembly I want show a total of 5 7/8" from the top of the drain shoe to the bottom of the included 3 inch tailpiece. And the installation instructions explain that 1-2 inches of the tailpiece actually extend into the p-trap inlet. Basic math tells me that the bottom of the tub would only need to be about 4-5 inches higher than the inlet.
    Any ideas where the estimator might be getting the additional inches? Are there additional parts required by code that's not sold in these standard kits? I've asked for clarification from the estimator, but he hasn't really explained it. I'd hate to build a 10-inch platform when a 7-inch platform would do just fine (as was there before). 10-inches is a big step up and would bring the tub way too close to what's already a low, sloped ceiling. Also, I'd hate to buy an drain/overflow kit that doesn't meet plumbing code for some reason.
    John
  2. dcelite
    dcelite Plumber
    Oct 5, 2009
    Los Gatos, CA
    As far as I know, the vertical distance between a fixture outlet and the trap weir shall be as short as practicable, but the tailpiece from any fixture can not exceed twenty four inches in length. (section 1001.4 tailpieces). Sounds like you can go as short as you like.
Similar Threads: Minimum vertical
Shower & Bathtub Forum & Blog How do we replace 5'0 bathtub with minimum damage? Jan 5, 2017
Shower & Bathtub Forum & Blog Bathtub leveling with mortar - Minimum thickness? Apr 18, 2016
Shower & Bathtub Forum & Blog Minimum stud spacing for Delta/Pex shower controller?? Nov 3, 2011
Shower & Bathtub Forum & Blog Is there a California building code stipulating minimum distance from tub to toilet? Aug 20, 2010
Shower & Bathtub Forum & Blog Fixing poor tub surround - how to seal vertical gap? Nov 24, 2015
