Minimum drain pipe size for a lav
Discussion in 'Canadian Plumbing Code Questions' started by poky1234, Mar 31, 2013.
  1. poky1234
    poky1234 New Member
    Dec 17, 2012
    Woodbridge Ontario
    Hello, Can someone tell me if an 1 1/4 pipe can be used to drain a lav? The drain pipe would run 4 to 5 feet ,then connect into the vertical 3 inch main waste stack. Also , because of the short distance,would it still require its own vent?
    Thanks
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    In the U.S., the trap and trap arm of a lav is commonly 1-1/4", but the drain is run in 1-1/2".
    From the International Plumbing Code (IPC)
  4. Terry
    Aug 17, 2004
    The lav should have a vent before it enters any "waste" stack.
    A lav can wet vent a shower, tub or toilet, but you can not run down waste on top of it in that manner.
  5. mikeplummer
    mikeplummer Plumber
    Mar 28, 2012
    Ontario, Canada
    it can be 1-1/4" drain and can be stack vented if there is no discharge upstream of where it connects to the 3" main. If there is discharge from above that connection then it does require tis own separate vent
  6. poky1234
    poky1234 New Member
    Dec 17, 2012
    Woodbridge Ontario
    Thanks for the replies guys. Mikeplumber, that is exactly what we are doing. I just needed to know if 1 1/4 is ok. This is for a custom floating boathouse that has very tight quarters and is a little unconventional. I have another question but I'll post it with a pic and drawing.
Similar Threads: Minimum drain
Canadian Plumbing Code Questions minimum size for washing machine fixture Oct 25, 2010
Canadian Plumbing Code Questions Washer Standpipe and Laundry Sink Drainage Reconfiguration Jan 14, 2017
Canadian Plumbing Code Questions Washing Machine with Utility Sink - 1-1/2" Drain! Dec 6, 2016
Canadian Plumbing Code Questions Want to tie into washing machine drain Mar 7, 2016
Canadian Plumbing Code Questions Dishwasher direct drain to basement and main soil stack Sep 18, 2015
