Minimum distance from trap to sani-tee
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by techinstructor, Mar 26, 2011.
  1. techinstructor
    techinstructor New Member
    Apr 24, 2009
    North Carolina
    I've read about maximum distances allowed from the trap to the sani-tee (and vent) but I was wondering if there is a minimum horizontal distance that should be maintained. In other words can the j bend be trimmed to a shorter length if desired? We'd be using 1 1/2" pipe at this location. I also have a 2" trap for the washer that will connect to a sani-tee that will not be in the wall. Is there a minimum length for the pipe coming from the trap to the sani-tee and vent?
    Thanks
  2. dlarrivee
    dlarrivee New Member
    Jun 28, 2009
    Foam/Fireproofing/Acoustical
    Canada
    Generally, double the diameter of the given pipe.
  4. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    Twice the diameter of the pipe, elswize you have an S trap
  5. Yersmay
    Yersmay Writing, constructionDIY Member
    Sep 9, 2005
    writing, construction
    Los Angeles
    I posted an identical question sometime ago and got some very interesting answers. I tried lifting the title of that thread and placing it in this post but I'm not sure it worked. At any rate, the thread can now be found in the Code Question forum, UPC. The title of the thread is:
    trap arm question, UPC.
    If I didn't successfully insert a link to my past thread, maybe someone can do that for me.
  6. Gsalet
    Gsalet George the Plumber
    Sep 19, 2010
    San Francisco
    If you can make the connection without cutting into the radius of the trap arm it should be OK, No Minimum sited in the code
  7. techinstructor
    Apr 24, 2009
    North Carolina
  8. jimbo
    jimbo Plumber
    Since the code says 2 pipe diameters developed length from the weir of the trap to the inner edge of the vent, I think in practical terms, it would be hard NOT to meet that spec.
  9. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    That would be a crown vent not an s-trap.
  10. Winslow
    Winslow Plumber
    Dec 30, 2005
    Hawaii
    Or a crown vented trap if the drain was on the horizontal. Either way it's illegal, at least under the UPC.
  11. techinstructor
    Apr 24, 2009
    North Carolina
    Ok, it is illegal in NC too. After posting this I found this in the NC Code:
    Thanks for the responses.
Similar Threads: Minimum distance
Plumbing Forum, Professional & DIY Advice minimum distance from shower drain centerline to joist Mar 31, 2010
Plumbing Forum, Professional & DIY Advice Minimum toilet to sink distance Aug 13, 2009
Plumbing Forum, Professional & DIY Advice Minimum toilet vent size? Dec 11, 2016
Plumbing Forum, Professional & DIY Advice Minimum drop for toilet in basement Jul 8, 2016
Plumbing Forum, Professional & DIY Advice Minimum guest bath dim Jul 20, 2015
