Mini split install questions
Discussion in 'HVAC Heating & Cooling' started by mar3232, Jul 23, 2012.
  1. mar3232
    mar3232 Member
    Oct 31, 2011
    Indiana
    I'm not an HVAC pro but I would say I'm a semi-pro in just about everything else -- electrical, construction etc. and decided to do a small mini split in my bedroom (9000 btu).
    It will be a breeze to do the mechanical stuff and electrical -- the lineset will probably be less than 10 feet, where I plan on putting it. (probably be more like 6 feet or so).
    I've seen a few installs on youtube and it looks pretty straightforward but my question is this --
    If I'm careful and absolutely nothing is leaking, aren't these designed where a DIY'er can actually just connect the lineset and you can pretty much start using them without any additional refrigerant charging?
    I know a lot of you will say get a pro to check it out, but realistically? Guarantee the installation will be A1.
    I guess the hardest part are the bends in the lineset? -- do you guys use some sort of jig or tool for this?
    thanks.
  2. jimbo
    jimbo Plumber
    With all due respect: BACK THE TRUCK UP. Most of these systems require that the system be evacuated to remove air and non-condensibles, BEFORE opening the king valve to let the charge out of the condensing unit into the system. The factory charge is APPROXIMATE for x many feet of line, but you must set the super-heat or sub-cool using gauges. This is NOT plug and play or DIY.
  4. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    And, the charge on mini-splits is critical and weighed in. Gauges are useless too.
  5. mar3232
    mar3232 Member
    Oct 31, 2011
    Indiana
    Ok. Maybe if I do all of the mechanicals and Mr HVAC approves the install, I can save a few bucks (always on top of my mind). Even a run of 6 feet makes no difference eh?
  6. mar3232
    mar3232 Member
    Oct 31, 2011
    Indiana
    By the way if anyone is close to Indiana, have a nice Trane heat pump system available -- only 3 years use -- make me an offer.
Similar Threads: Mini split
HVAC Heating & Cooling Ducted and ductless mini split system installation cost - reasonable? Jan 17, 2017
HVAC Heating & Cooling Mini Splits, Single vs Multi Zone Condensers Sanity Check Jul 21, 2016
HVAC Heating & Cooling Mini-Split help Jun 10, 2016
HVAC Heating & Cooling Mini-split p-trap May 30, 2016
HVAC Heating & Cooling Ductless Mini Split Cooling Design Apr 27, 2016
