min spacing hot cold copper lines...
Discussion in 'Remodel Forum & Blog' started by chris fox, Jan 9, 2008.
  1. chris fox
    chris fox Member
    May 9, 2007
    near phoenix AZ
    I had to move 1/2" hot/cold copper lines for one of the sinks in my master bath. I noticed for both sinks that there wasnt a consistant spacing between the individual hot/cold lines as they exited the wall. I already moved the lines but now starting to think if they need more seperation. There is about 3" distance (ctr to ctr), is this enough??
    Does code require a min distance between the two(hot/cold)? I thought to ask on here before searching local plumbing codes.
    Thanks
    Chris
  2. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    4"is standard unless you have a wide spread faucet for a lav or 6" K/S faucet.
  4. Terry
    Aug 17, 2004
    If you are talking copper stub outs for the shutoff valves, then no, there is no minimum.
    As long as you can install shutoffs, it works.
    Inspectors don't like to see the copper pipes touching, they conduct heat and cold.
    PEX on the other hand, can be bundled. They don't conduct heat or cold.
  5. chris fox
    chris fox Member
    May 9, 2007
    near phoenix AZ
    Thanks guys,
    I like to cover my steps. I measured again its more towards 3.25", I will leave it.
    Another related question, what are prefered shut off valves for sinks. The house was installed with these push/pull types that look to fit by push on. I recently i have seen 1/4 turn valves.
    I havent had a leak anywhere in the house but could assume the push/pull offers no ability to change out without cutting copper?
    Which is the prefered shut off valve?
    thanks
    Chris
Similar Threads: spacing cold
Remodel Forum & Blog "Normal" spacing from wall for recessed lighting? Nov 21, 2009
Remodel Forum & Blog plumbing in a cold zone Aug 29, 2008
Remodel Forum & Blog hot cold shut off valves... Jan 10, 2008
