I recently removed silicone/caulk due to stubborn mildew around my shower floor. I fear the moisture may have extended deep under shower wall panels. The outer lining of the shower drain is also constantly moist even after 2 days of non-use.
Should I expect to remove my shower panels and deal with the moisture problem. I'm treating mildew and allowing the area to dry out. I'm not sure how long to wait (it's been 2 days since I've used the shower). There was a lot of moisture and mildew when I scraped off the silicone today.
If the damage is extensive, can the shower panels be removed to fix the problem, or should I expect a contractor to replace my shower. I'm just curious what I'm in for. I appreciate any help. Thanks for your time!
