Metal Shower Spout/Pipe to CPVC Fitting
pastorerik
Pennsylvania
I have cpvc pipes. At the top there is a threaded fitting with a rubber gasket inside. My question is how to get the angled shower head pipe in so that it is tight enough and lined up. Mine needs to be tighter but would need another full turn to line it up right, I am afraid it will either destroy the rubber gasket or break the fitting. Thanks in advance for any advice.
Cacher_Chick
Test, Don't Guess!
Most people who have done some plumbing know better than to use plastic threaded fittings because of the likelihood of cracking. I would never use CPVC on a shower riser.
The only thing you can do is try using a liberal amount of pipe dope on the threads and turn it in until it is fairly tight and facing the right direction. If that does not work, it's time to get out the saw for some re-work.
Kreemoweet
Seattle. WA
Thread tape will work a lot better than pipe dope for that purpose, especially the thicker pink or yellow tape.
Cacher_Chick
Test, Don't Guess!
"Just enough" teflon tape would work, but too much might result in a cracked fitting.
I have also seen a lot of shower arms with poorly cut threads- I have one laying here somewhere that looks like it has acme thread instead of pipe.
pastorerik
Pennsylvania
Thanks for all the help, I will try the teflon tape. Can't do anything about the riser being cpvc, it has been in there for years with no problems so far as far as cracking, etc. It doesn't leak as long as it is tight enough, the problem is the alignment is about 1/8 of a turn too far. If I do have to replace it I'll use one with the brass threads. Great forum, thanks all.
