Metal Bonding?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by molo, Aug 3, 2007.
  1. molo
    molo Member
    Sep 23, 2006
    Cold New York
    Electric Hot Water Tank with Copper Nipple coming out of the tank.
    THE COPPER NIPPLE WON'T MOVE!!!
    2 guys holding the tank, 2 guys on a big wrench, it won't move!
    I heated it, it won't move!
    I banged on it and drilled it, it won't move!
    I ruined the tank, it still won't move! (old tank, no big loss)
    Why did this copper become part of the tank like this?
    TIA,
    Molo
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Try PB Blaster on it. Spray it, let it sit for 30 minutes, then try it. I suspect it was just put on mega tight without pipe dope and some corrosion on the threads. This would be a good test for the PB Blaster.
  4. GrumpyPlumber
    GrumpyPlumber Licensed Grump
    Jun 18, 2007
    Plumber, self employed
    Licensed Grump
    I'd bet even that wouldn't do it, not if 4 guys were tweaking it with a wrench....I bet the copper has corroded into a bond with the steele from years of galvanic action.
    Molo...keep us apprized.
  5. molo
    molo Member
    Sep 23, 2006
    Cold New York
    here's a photo, it was bonded! I literally beat the copper with a hammer and also used a drill bit and a flathead screwdriver that i beat on with the hammer> the copper wouldnt seperate!!
  6. GrumpyPlumber
    Jun 18, 2007
    Licensed Grump
    Molo...sorry, but yer not gonna be using that heater again.
  7. molo
    molo Member
    Sep 23, 2006
    Cold New York
    Come on! isn"t there a tape product that would work to patch that hole?
    tia<
    molo
  8. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    Duct tape if you have only 1 pound of water pressure
    Next time use your blue tip wrench (torch)
    It will come out for sure, especially if you pull the flame away and pour water on the copper fitting so it will shrink while the tank port is cherry red......or white depending on how pissed off you are at getting it out.
    I hate leaving MIP's in the tanks too......I like getting all the scrap I can before the junk man gets my tanks.
    :eek:
  9. GrumpyPlumber
    Jun 18, 2007
    Licensed Grump
    oh geesh...I'll grab the copper, sure...but I stop at having to work for it.
  10. got_nailed
    got_nailed DIY Senior Member
    Jan 11, 2006
    I’ll weld it up for you
  11. construct30
    construct30 New Member
    Jun 16, 2007
    NorthWest PA
    I guess they should have used one of the heat trap nipples on that.
Similar Threads: Metal Bonding
Plumbing Forum, Professional & DIY Advice Metal roof- vent flashing, small ones for 2" & 1.5" Oct 17, 2016
Plumbing Forum, Professional & DIY Advice Installing a new faucet, pressure seems too high going from Flowtite piping into new metal piping Mar 15, 2016
Plumbing Forum, Professional & DIY Advice FALLING DOWN c1966 rimless undermount sink, clips to metal bezel Jul 29, 2015
Plumbing Forum, Professional & DIY Advice Buried Fernco/Mission coupling - use metal banded or all rubber? Aug 15, 2014
Plumbing Forum, Professional & DIY Advice Backflow fitting needed? Is different metals acceptable? Aug 8, 2014
