Mendota cast iron(alcove) tub install on slab floor
Discussion in 'Shower & Bathtub Forum & Blog' started by Sammy M, Mar 29, 2014.
  1. Sammy M
    Sammy M New Member
    Mar 29, 2014
    ca
    I noticed on past discussions the need to install a ledger board for the tub when the floor was plywood. Is this still recommended for a slab floor installation?
    Thanks a lot for the advice.
  2. Terry
    Aug 17, 2004
    Normally the feet on a cast iron tub are a bit too high to touch the ground.
    Kohler like shims.
    I don't know how that is done with three closed in sides in a remodel. Perhaps in new construction you can do that.
    Regardless, the instructions call for metal shims. Where do you get those in different thicknesses?
    I've been installing with a ledger board. These tubs weigh over 300 pounds, and once they drop down, they pretty much stay down.
  4. hj
    Kohler tubs typically have feet that rest on the ground, but a ledger board is just added security. It makes sure the tub moves with expansion and contraction of the wall structure.
  5. Sammy M
    Sammy M New Member
    Mar 29, 2014
    ca
    Thanks for the advice...the odd thing about the apron side, is that the cast iron is molded in such a fashion that you cannot run a full size 2x4 ledger board across the whole length against the wall. The tub strength is obviously engineered with a triangular support in the shaping to support which is right in the way of any ledger capability at the ends. I suppose I can still put a ledger in for the tub minus a foot at either end. Have you noticed this on the new Mendota...60x 32?.....thanks again for your thoughts.
Similar Threads: Mendota cast
Shower & Bathtub Forum & Blog Has anyone build tub enclosure for kohler 5-ft mendota cast iron bath tub? Sep 23, 2011
Shower & Bathtub Forum & Blog Installed an Americast tub with tile surround in a rental unit, cleaning? Yesterday at 9:54 PM
Shower & Bathtub Forum & Blog Cast Iron Shower drain on concrete Wednesday at 2:58 PM
Shower & Bathtub Forum & Blog Cast Iron Kohler "Bellweather" install Feb 25, 2017
Shower & Bathtub Forum & Blog Cast iron drain...can I avoid the jackhammer? Jan 13, 2017
