Medicine cabinet width for 30" vanity....
Discussion in 'Remodel Forum & Blog' started by chrisexv6, Nov 12, 2008.
  1. chrisexv6
    chrisexv6 Member
    Oct 6, 2008
    What width would you look for to put a medicine cabinet over a 30" vanity?
    Wife wants a med cab. with only one door. Apparently, its tough to find that in a wider cabinet (20-24" wide).
    Im not sure a narrow cabinet (standard size being about 15 or 16" wide) would look good with a 30" wide vanity below it.
    Ive found a Nutone model that comes oversized but its well out of budget.
    Any advice?
    Thanks.
    -Chris
  2. jadnashua
    Two things I look for in a mirrored cabinet over the sink: centered over the sink and recessed. Recessing can be a problem as that is likely where the vent pipe goes. In my bathroom, I had to build the wall out to be able to recess the cabinet. I don't think you'd like a large single panel door if the cabinet gets very wide - you'd have to back away as you opened it with the typical vanity depth and if it was left open, you might bump your head into it, especially shorter people and children. Considering it contains glass, that's not a great idea.
  4. chrisexv6
    chrisexv6 Member
    Oct 6, 2008
    Yeah, I didnt think about the backing away factor. The vanity itself is 22" deep, so 20" would probably be the max width I would be looking for.
    The reason Im asking is because I found a good deal on a really nice Nutone cabinet, but its only 15" wide. Sitting there on a wall I figured it would look tiny compared to a 30" vanity.
    Definitely will be centered and recessed........they furred out the wall my vanity goes on to 6" deep, so I should easily be able to recess a 4" deep cabinet. Plus it looks like the vent wont be in the way (2nd floor of my house was an addition, and it looks like they changed all sorts of plumbing during it, so its blind luck that a vent was moved out of the way).
  5. hj
    cabinet
    Single door cabinets are almost always designed to fit into a 14 1/2" stud space. Since the mirror has minimal overlap you will seldom find one more than 16" wide.
  6. Southern Man
    Southern Man DIY Hillbilly
    Jun 27, 2008
    North Carolina
    Because of the stud placement/ center with sink/ vent pipe issues, you'll have to determine if its possible first. An easy way out is to put a wall hung cabinet over the toilet, which will give her more storage space, then buy a simple wall hung mirror for the vanity.
  7. Southern Man
    Jun 27, 2008
    North Carolina
    I didn't see this with my earlier comment. Maybe you can get some mirrors to match, on one side of the other or both, to balance it out and get the width that you want.
Similar Threads: Medicine cabinet
Remodel Forum & Blog Bathrom Vanity, Medicine Cabinet, Sconce Install Questions Sep 28, 2013
Remodel Forum & Blog Medicine Cabinet Hinge Aug 31, 2010
Remodel Forum & Blog New medicine cabinet install--old walls! Oct 31, 2008
Remodel Forum & Blog Installing DOMJSO double-sink without countertop on a single 36" cabinet Feb 29, 2016
Remodel Forum & Blog Installing a single oven below the counter. Anyone done this? What size base cabinet? Jun 4, 2014
