Measuring Rough IN
Discussion in 'Toilet Forum discussions' started by smurfmeister999, May 18, 2006.
  1. smurfmeister999
    smurfmeister999 New Member
    May 18, 2006
    I have a toilet (unnamed but with a UPC stamp) and I'm not sure how to measure the rough in. When I measure from the wall to the centre of the bolts I get 11 1/4 inch. I don't know whether the bolts are always aligned with the center of the drain or not. The wall is ceramic so I'm not sure whether it's shortening the actual rough in length or not. If my measurement is correct, will a toto 12 inch rough in toilet fit?
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    The bolt holes are in the center of the the drain outlet, so that's measure from that point to the finished wall. Usually there is a little fudge factor, but don't count on it too much.
  4. jimbo
    jimbo Plumber
    San Diego, CA
    Don't measure any base molding. In your case , the rough may have been set at 12 assuming just drywall. When the ceramic was added, it took away 1/2".
    You will have to look at actual spec sheets for toilets. Many toilets have 1/2" tolerance; some will NOT work with being 3/4" under.
  5. Terry
    Aug 17, 2004
    The Toto Drake and the Ultramax will work with 11-1/4" on the rough-in.
  6. maddfrog
    maddfrog New Member
    May 19, 2006
    California
    I'm in the same boat - I measured from the drywall to the center of the bolts and it's 11 1/4. I'm just beginning a bathroom remodel and we're planning on replacing the toilet during the process.
    How can I determine whether a specific toilet will work?
    Are there any options for making a toilet designed to work with the standard 12" rough-in work other than moving the flange?
  7. Terry
    Aug 17, 2004
    Almost all toilets are built with 3/4" of fudge room in the back.
    If you click on a toilets pdf spec file, it will show the back wall clearance.
  8. maddfrog
    maddfrog New Member
    May 19, 2006
    California
    Thanks
    Good to know - thanks.
  9. smurfmeister999
    May 18, 2006
    I checked the specs on my toilet and it appears that it has a 5/8" space allocation between it and the wall. If I add a 1/4" for the ceramic wall I should be ok. Thx
Similar Threads: Measuring Rough
Toilet Forum discussions Measuring rough in Apr 6, 2006
Toilet Forum discussions Measuring For A New Toilet Jan 6, 2009
Toilet Forum discussions Rough in 1/2 too short: Offset or Caroma? Wednesday at 11:54 AM
Toilet Forum discussions Basement rough in Mar 14, 2017
Toilet Forum discussions TOTO Ultramax II rough in distance Jan 31, 2017
