maximum gap between toilet flange and floor
Discussion in 'Toilet Forum discussions' started by cjc, Feb 18, 2013.
  1. cjc
    cjc New Member
    Mar 12, 2005
    Wisconsin
    I am in the process of remodeling two bathrooms. I'm planning to replace the tile flooring with vinyl. For one of the toilets, I can easily replace the flange by cutting the pipe from the floor below. The second toilet is not so easy. I don't have easy access to the waste pipe from underneath because it is directly above a heating duct. It also looks like the flange is connected directly to an elbow. The drain pipe is 3" inside diameter. I understand it is preferred to have the flange resting directly on top of the floor, but it would require either taking a heat duct apart or pulling up the subfloor. So my question is if I tear out the floor and put down new underlayment and vinyl, I'll have a 1/8" gap between the flange and floor. Is this acceptable, or will I need to shim the flange and toilet? And if I shim the flange will the toilet need to be shimmed as well or would it still be possible to push it down tight to the floor?
  2. hj
    As long as there is a "gap" between the flange and the bottom of the toilet when the toilet is sitting on the floor, the flange does not have to be adjusted.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    A 1/8" gap is not a problem. You might want to use a jumbo wax ring to compensate for that slight difference.
  5. mtcummins
    mtcummins In the Trades
    Jun 25, 2010
    General Contractor/Property Manager
    Pittsburgh PA
    Why a jumbo if the flange is too high?
  6. jadnashua
    Put a shim underneath the flange so that it fills that gap, and then rescrew it to the subfloor. You might be able to use a few washers at the screw holes, but a solid ring may be better. Being 1/8" higher than design rarely would make it too high for the toilet to sit properly, but make sure the toilet DOES sit flat over the flange before setting it with the new wax ring. There has to be at least some room for wax between the toilet and the flange for it to seal properly. And, if the toilet rocks, add shims there to prevent it.
  7. Gary Swart
    Sep 1, 2004
    Yakima WA
    Good catch mtcummins. I just reversed the whole thing. Of course you wouldn't need a jumbo seal in this case. That would be needed if the flange was 1/8" too low, not high. My bad.
Similar Threads: maximum between
Toilet Forum discussions Drain droppage - Maximum - Minimum - Precise? Mar 31, 2012
Toilet Forum discussions The Maximum Performance (MaP) Test Aug 22, 2006
Toilet Forum discussions How is the toilet made the difference between 1.28 and 1.60 GPF toilet? Saturday at 9:18 PM
Toilet Forum discussions Bad float? Delay between flush and beginning of fill Jul 8, 2016
Toilet Forum discussions Difference between Ultramax and Ultramax II Jun 20, 2016
