Max drop out the bottom of a toilet.
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by lahabra, Dec 22, 2007.
  1. lahabra
    lahabra New Member
    Dec 21, 2007
    California
    Is there a maximum vertical drop from a toilet flange to the 90* elbow?
    I am considering a design which would have an ~18†drop to an elbow, then a 7’ x 4" horizontal arm then a vertical vent.
    I am planning a major bathroom re-configuration. I am trying to avoid a lot of cement cutting. I will have my work inspected.
  2. Terry
    Aug 17, 2004
    With UPC plumbing code, it's six feet developed length from the flange to the vent.
  4. lahabra
    lahabra New Member
    Dec 21, 2007
    California
    I have an old book that says I can have a tolet 10' away from the vent if I use 4" pipe.
    Are you quoting a rule for 3" pipe? Or is my book out dated?
  5. Terry
    Aug 17, 2004
    3" and 4" for toilet.
    If you have things other than a toilet, then it's 10 feet for 4" and six for 3"
    But a toilet is always six feet whether it's 3" or 4"
  6. lahabra
    lahabra New Member
    Dec 21, 2007
    California
    Thanks for the clarification.
    So is there a limit to the length of the drop? or could I have a 5' drop into an elbow?
    WC
    . 5'
    90*...v....................................street
  7. GrumpyPlumber
    GrumpyPlumber Licensed Grump
    Jun 18, 2007
    Plumber, self employed
    Licensed Grump
    My code allows up to 20" drop without a seperate vent on WC's, a 4" line can run up to 8' without a vent.
    It all depends on your local code.
    My code says your ok.
  8. Winslow
    Winslow Plumber
    Dec 30, 2005
    Hawaii
    24" according to the UPC
Similar Threads: drop bottom
Plumbing Forum, Professional & DIY Advice OK NOT to use a Long Sweep 90 at the bottom of a drop? Aug 23, 2010
Plumbing Forum, Professional & DIY Advice Drop ear questions for new hand shower Jan 24, 2017
Plumbing Forum, Professional & DIY Advice Main Water Feed - 20psi Pressure Drop When one Fixture is Open Dec 23, 2016
Plumbing Forum, Professional & DIY Advice Drop in water pressure after new softener put in Nov 3, 2016
Plumbing Forum, Professional & DIY Advice How to eliminate pressure drop? Oct 16, 2016
