Materials needed to PEX Bathroom
Supperfly17
Ontario
Hi there I am about to PEX my basement bathroom. I am just building a materials list before I go shopping.
I will be using PEX-a tubing with a cold expansion fitting. I have to tool/cutter already.
So I need:
1: 1/2" PEX-a Tubing
2: Cold expansion fittings
3: A few right angle polymer fittings
4:A few elbow sleeves
5:Shower mixed valve
6: Drop ear elbow for the shower head
7: A few abrasion clips, pipe insulation foam, plastic pipe supports
Am I missing anything else?
What exactly do I need for the PEX ends for the hot/cold vanity and cold toilet?
Thanks for your help.
You need to figure out how you will come out of the walls for lav and toilet connections.
I think you want to look further. What will you want to end up with? You will want 3 stop valves supplied with water that can then provide the water to the toilet and lav. Right?
So I think you want to identify those and how they will be mounted. I don't have a suggestion for what you want to select, but I would think picking those out would be important to running the pex.
