material for shower stall ceiling...
Discussion in 'Shower & Bathtub Forum & Blog' started by rdavison39, Jan 5, 2011.
  1. rdavison39
    rdavison39 New Member
    Jan 5, 2011
    Toronto, ON Canada
    I'm hopefully going to create a shower stall that is normal height (8') with tiles going up the walls to 7'. I don't plan on tiling the last foot nor the ceiling. What material should i use for the ceiling? That is, should it be the 'green' moisture resistant drywall or the cement board. Just thinking if i use cement board it might be hard getting a good finish on it without lots of mud?
    THoughts?
    Thx
    Ron
  2. jimbo
    jimbo Plumber
    It is not necessary to use cement board, and I am not sure code allows greenboard on the ceiling, because it is structurally not adequate. PAINT is what you put on the ceiling. A good coat of quality semigloss, and ventilation....get about twice as many CFM as you though you need!
  4. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    Good advice Jimbo.
    I believe that Green Dry Wall or Moisture resistant drywal is allowed in a shower above 6' and on the ceiling. Your framing members will need to be on 16" centers but 12" centers would be better on the ceiling.
    There is a product called Green EBoard that we have been using with great success and this is a step up from Green Dry Wall.
    Make sure you remove all dust from the ceiling from drywalling. Use a great primer like Zissner Yellow Label (Cover Stain) and a good SemiGloss like Jimbo suggested. In the bathroom I like to use Oil based paints that require paint thinner to clean up. There are many good latex bathroom paints but I have yet to find one that competes with an "Old School" Semi Gloss Oil....
    JW
  5. jadnashua
    Normal greenboard is no longer in the national (US) codes for use in damp areas...either drywall if 'dry' or cbu if 'wet'. Local codes may not have adopted this yet, so you have to abide by their rules. Greenboard's facing isn't as strong as drywall's, and can sag on a ceiling if not supported at 12" intervals, which usually means stapping, and a resulting lower ceiling height in that room which is also a pain. So, regular drywall, with a good coat of paint and adequate ventilation.
  6. rdavison39
    Jan 5, 2011
    Toronto, ON Canada
    Thanks all for the quick and helpful replies
    Ron
Similar Threads: material shower
Shower & Bathtub Forum & Blog Recommended shower install materials?? Jan 11, 2012
Shower & Bathtub Forum & Blog Shower base material Nov 30, 2009
Shower & Bathtub Forum & Blog need help identifying tub/shower surround material Apr 23, 2009
Shower & Bathtub Forum & Blog What's your favorite shower pan material? Aug 28, 2008
Shower & Bathtub Forum & Blog Best material for a shower base (pan) Feb 22, 2008
