Master bath addition
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by davidffd, Mar 7, 2007.
  1. davidffd
    davidffd New Member
    Mar 7, 2007
    Firefighter
    Farmington, CT
    Hello,
    First time poster here. I got your site from John Bridge tile forum. I am in the process of an addition to our house. It is a two story addition with a 400 square foot living room and a 400 square foot bed and bath on the second floor. I have done some plumbing in the past, last year I gutted and redid another full bath in the house. Pretty simple set up though. I am going to try to do this one myself. I have pulled all the necessary permits and will have it inspected. My question for now is on the supply pipes. I have all new 3/4 inch copper in the old part of the house with 1/2 inch branches to the fixtures. The new bathroom is about 20 feet from those 3/4 inch lines. Should I run 3/4 inch to the new bath and branch off with 1/2 or could i just run 1/2 for the supply and branches. There will be a whirlpool tub, 2 sinks, toilet and separate shower. Thanks for any help.
    Dave
  2. geniescience
    geniescience Homeowner
    Nov 27, 2005
    ditto
    3/4" performs better
    hi Dave!
    i'd use 3/4". No extra cost, and a lot more performance. More flow and less noise flowing.
    david
  4. davidffd
    davidffd New Member
    Mar 7, 2007
    Firefighter
    Farmington, CT
    Thanks Dave,
    I am pretty confident on piping the supply lines but the pvc drains I'm not positive on. Can you recommend any good sources of info so I make sure I get the drains sized properly and run the vents correclty?
    Dave
  5. markts30
    markts30 Commercial Plumber
    Sep 25, 2006
    Commercial Plumber
    Phoenix, AZ
    Sketch out a floor plan with the existing piping (waste) that you are going to tie into...
    Then draw the plumbing the way you think it should be...
    We can all work from there....
  6. hj
    drains
    Didn't you have to submit a drain and water plan to the building department when you got the permit?
  7. davidffd
    davidffd New Member
    Mar 7, 2007
    Firefighter
    Farmington, CT
    No, I did not have to submit a plan. They really only focused on the building construction and insulation. Small town in Connecticut with one full time inspector. Any tips on posting a sketch. I'm not the best with computers.
    Dave
Similar Threads: Master bath
Plumbing Forum, Professional & DIY Advice Water Damage in wall behind bathtub/shower in Master Bath Jan 15, 2017
Plumbing Forum, Professional & DIY Advice Bad AAV smell in my master bathroom? Help! Dec 23, 2016
Plumbing Forum, Professional & DIY Advice Masterbath drain HELP Dec 14, 2016
Plumbing Forum, Professional & DIY Advice Master bath wet vent question Dec 4, 2016
Plumbing Forum, Professional & DIY Advice Re route vent in masterbath Sep 8, 2016
