Mark 100 problem?
Discussion in 'Water Softener Forum, Questions and Answers' started by Flanadr11, Sep 12, 2012.
  1. Flanadr11
    Flanadr11 New Member
    Sep 12, 2012
    Indiana
    For a little over a week now we have been experiencing water flow problems. At times, you may end up with just a trickle for a few moments.....it does vary some. I bypassed the water softener yesterday and the flow to the house has never been better. There has not been one episode of poor flow since. Can anyone offer advice on what the potential problem is and a remedy. Thanks for any help.
  2. Akpsdvan
    Akpsdvan In the Trades
    Dec 29, 2009
    Business owner/service and sales
    Alaska
    Most likely there are a number of things going on between the valve body and the media in the tank.
    Has the system been using salt over the last few months with no change?
    There is one place for the culligan that if it gets some stuff in it the flow will go down hill.
    Age of your system? City water or Well water? Pre filter before the culligan?
  4. Flanadr11
    Sep 12, 2012
    Indiana
    No pre filter, city water, to the best of my knowledge 12 y/o system. It has been using salt over the last few months with no apparent problems.
  5. Akpsdvan
    Dec 29, 2009
    Alaska
    I am not sure if Culligan used a part in the 100 like they did in the earlier systems, but the part is where the incoming water goes through the valve on its way into the media tank.
    The part was like a flow deflector and if there build up then it will choke off the water flow into the system.
  6. Flanadr11
    Sep 12, 2012
    Indiana
    Thanks I will check that out in the morning.
  7. rjh2o
    rjh2o Member
    May 10, 2011
    Michigan
    Most likely a plugged outlet manifold. Use to be a pretty common problem with Culligan units. Pull the outlet manifold, clean it and re-install
    RJ
Similar Threads: Mark problem
Water Softener Forum, Questions and Answers Culligan MARK 100 PROBLEM Feb 7, 2012
Water Softener Forum, Questions and Answers Culligan Mark 89 always draining Jan 7, 2017
Water Softener Forum, Questions and Answers Culligan Mark 59 Feb 18, 2016
Water Softener Forum, Questions and Answers Culligan Mark 100 help Jan 29, 2016
Water Softener Forum, Questions and Answers Culligan Mark 59 started continuous flow to drain Jan 27, 2016
