Manual Thermostat
Discussion in 'HVAC Heating & Cooling' started by Fudog, Oct 29, 2011.
  1. Fudog
    Fudog New Member
    Dec 31, 2007
    I have one small bedroom with radiant ceiling heat that does not seem to be working. The thermostat is a manual type 240 volt. I am wondering if the thermostat is bad and how I should check it. I have some electrical knowledge and test meters but not sure about testing a manual thermostat. I have not read alot of info about radiant ceiling heat troubleshooting. I am guessing that if the thermostat is not bad that the heating elements are bad and probably would have to go with baseboard heat. Thanks for your time.
  2. jimbo
    jimbo Plumber
    San Diego, CA
    You would have 240 volts across the two input wires, and 240 across the two output wires when the stat calls for heat. Probably you should not be messing around with 240 volts.
Similar Threads: Manual Thermostat
HVAC Heating & Cooling Converting a manual switch heating zone to a thermostat heating zone Mar 10, 2010
HVAC Heating & Cooling Manual lighting gas boiler Feb 17, 2010
HVAC Heating & Cooling Replace Duct vs. Manual Damper May 11, 2009
HVAC Heating & Cooling Manual J Does it sound correct Oct 30, 2008
HVAC Heating & Cooling Radiant Heat Concrete?? Manuals Feb 1, 2008
