Manual J Does it sound correct
Discussion in 'HVAC Heating & Cooling' started by weather777, Oct 30, 2008.
  1. weather777
    weather777 New Member
    Sep 30, 2008
    A Manual J was done to produce these units,but seems to me the units are too small.I am mainly concerned about the cooling capacity.
    Heating Degree Days: 4400
    Cooling Degree Days: 1000
    House:Upper Level 1400 sq ft
    Lower Level 1400 sq ft
    A very small portion of the lower level is true basement ( the north wall and maybe fraction of the 1400sq ft) and the rest basically 1st floor like at 7 feet above ground.However,since the entry door is in the upper level its referred to as basement There is around 800 sq ft of crawl space under the lower level and will be sealed with a dehumidifier and 4inch pipe air supply.The house is tightly insulated and 2x6 construction.I want the temp in the summer to be able to cool to 65 degrees when 90 degrees outside.
    Results:
    Upper Level system: 2.5 ton
    Lower Level system: 1.5 ton
    Air Source Heat Pumps with Propane back up- 13 SEER A/C with variable speed fans
    Does that lower unit seem large enough to get the temps to desired level---seems low to me.
    Thank you
    PS--Does it matter if the lower level was entered into Manual J as basement vs 1st floor as far as tonnage it showed (1.5 tons)?
  2. jimbo
    jimbo Plumber
    San Diego, CA
    I will let the HVAC pros weigh in on the numbers. But I will say you are asking a lot to cool to 65º. Why do you want to do that? Most folks would find 65 to be uncomfortably cold.
  4. hj
    temerature
    Heating and cooling are almost a geometric curve. It takes a lot more energy to cool from 75 down to 65, than it does to cool from 85 down to 75. Why would you want a temperature that low?
  5. weather777
    Sep 30, 2008
    Due to health related issues.
  6. veesubotee
    veesubotee New Member
    Nov 3, 2008
    manual J?
    Stating heating and cooling degree days does not give a true value for sizing heating/cooling, since your dealing with averages of temperatures in a period.
    Did your 'manual J' state heat loss and heat gain (sensible and latent)? This is what's needed.
    V
  7. jimbo
    jimbo Plumber
    San Diego, CA
    Don't mean to pry....but do you need it that cold, or do you need to reduce the humidity and filter the air. The latter two can be accomplished without the very low temp.
Similar Threads: Manual Does
HVAC Heating & Cooling Manual Thermostat Oct 29, 2011
HVAC Heating & Cooling Converting a manual switch heating zone to a thermostat heating zone Mar 10, 2010
HVAC Heating & Cooling Manual lighting gas boiler Feb 17, 2010
HVAC Heating & Cooling Replace Duct vs. Manual Damper May 11, 2009
HVAC Heating & Cooling Radiant Heat Concrete?? Manuals Feb 1, 2008
