Mansfield toilet!!
Discussion in 'Toilet Forum discussions' started by moisheh, Nov 16, 2009.
  1. moisheh
    moisheh New Member
    Sep 9, 2006
    Mexico and Canada
    Our home in Mexico has a Mansfield toilet installed by the previous owner. I hate that sucker with a passion. It is a low profile model with a shallow very wide tank. Our water varies from bad to really bad. The bad water played havoc with the Mansfield mechanism. Mansfield uses a different system than any other mfr. No flapper valve. I always had problems with it. Parts are not to be found in Mexico even though they have every toilet part known to man. Home Depot and a huge Plumbing supply store had nothing. I did find a few parts at Lowes. I finally gave up and installed a complete Fluidmaster kit. It works but not correctly. When you flush because of the wide tank the water level does not drop quickly and thus the flapper stays open. This causes the toilet to flush and then start to fill before flushing a second time. Makes it a real water pig. Due to the height limitation I cannot adjust the Fluidmaster any more. I am at the point where I want to buy another toilet and just give up. The Mansfield looks real "pretty" but works lousy!! Any ideas other than making it into a lawn ornament?
    Moisheh
  2. Basement_Lurker
    Basement_Lurker One who lurks
    Jun 21, 2007
    I smash things and demand money.
    Victoria, BC
    You could try an actuator flapper unit, but those can be a real pain.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I don't know what the Toto availability is in Mexico, but it would certainly be a better choice than the Mansfield. It might be a wise move to get a Toto with Sanigloss to help the cleaning issue.
  5. hj
    toilet
    IF the flapper is not closing fast enough, then you do not have the correct flapper. You need one for a 1.6 gpf bowl.
  6. Terry
    Aug 17, 2004
    hj has it.
    The new Fluidmaster kit may have an adjustment that will let you dial down the flapper timing.
    The flapper needs to drop quicker.
    So, either find the adjustment on the flapper you have, and dial it down,
    or replace with a flapper made for 1.6 gallons.
    If you need a short fill valve, the Korky 528 works well.
    Or you may be able to lift the collar on the Fluidmaster, and drop the valve down a bit, and then push the locking collar back.
Similar Threads: Mansfield toilet
Toilet Forum discussions A close look at the Mansfield Cascade rimless toilet -PICS- Jan 8, 2013
Toilet Forum discussions Has anyone seen this relativity new Mansfield rimless toilet? Nov 18, 2012
Toilet Forum discussions Mansfield 1983 Toilet: Tank to Bowl Gasket Nightmare Jun 14, 2011
Toilet Forum discussions Need help choosing a Toto..or Mansfield toilet May 18, 2011
Toilet Forum discussions Mansfield toilet overflows Nov 22, 2010
