Mansfield Outdoor Faucet Problem
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by daytonohioguy, Jul 20, 2008.
  1. daytonohioguy
    daytonohioguy New Member
    Jul 20, 2008
    I have a Mansfield outdoor faucet that was leaking out of the spout slowly. I am not really all that handy, but thought I could manage to replace the seat washer. I had a few washers I had bought in a box of several of the most common washers in leaks for faucets, and I thought I had the right one. I put it back together, and it stopped for about 3 days before it started to leak again.
    I figured I had the wrong washer so I took it back apart and replaced it with another one of the washers that looked right. I put it back together and when I turned the water on inside the house the water poured out of the faucet even when the water was turned off on the handle. I cannot shut off the water no matter if the handle is turned off or on unless I shut of the water inside the house. It is coming out like the faucet is turned on. Did I not put something back together right or is something broken? Any help is appreciated. I am hoping this is an easy repair as I finished the basement about 6 months ago with no access to the pipes near the faucet inside.
  2. Cass
    Cass Plumber
    Nov 12, 2005
    You need to replace the whole thing...If you are unable to do it your self you should call what ever plumber you use or depending on what part of Dayton your in I can come do it...I live in Warren Co.. PM me if I can help.
  4. PEW
    PEW DIY Senior Member
    Take the advice from Cass. It is very possible the threads on the stem and or housing are shot.
  5. daytonohioguy
    Jul 20, 2008
    Even if I can get a new stem for my faucet? I am trying to avoid cutting holes in the side of my newly finished basement.
  6. NPMSTR
    NPMSTR In the Trades
    Dec 28, 2004
    Plumbing Products, Sales and marketing
    Grandview, MO
    Hi Ohio Guy,
    To replace the stem will require no holes being cut in the walls, simply installs from the outside (as when you rebuilt the bibb washer).
    It sounds like when you repaired the bibb washer, the backflow device was damaged, leading it to continually leak outside the stem. If you replace the stem, that should stop the leak through the stem, however, of the seat is damaged from the leak, a tool is required to "dress" the seat and repair it.
    Prier bought Mansfield, so they provide stems through distributors. Get the length of your stem and buy a new one, then swap it out.
    Good luck.
  7. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    And then after all that the damn thing still leaks and you replace it...
    Somethings aren't worth a lot of time and effort.:cool:
  8. Cass
    Cass Plumber
    Nov 12, 2005
    Long ago I learned the hard way by repairing them and 1-6 months later getting a call back that the repair didn't work...I no longer repair them...I will turn down the job if they don't want it replaced...
  9. Redwood
    Dec 15, 2007
    Service Plumber
    I didn't learn about it from the callback factor...
    I learned about it from running around finding the part then going back and installing it and not having it work...
    Now I either reach in the truck and pull out a new one to install or drive away.
    The only ones I would even try to fix now would be the Moen H/C Sillcock (which hasn't happened yet) or, a Woodford. All the rest are disposable!
    Either way it's an exercise in futility!
Similar Threads: Mansfield Outdoor
Plumbing Forum, Professional & DIY Advice Mansfield outdoor anti syphon faucet Jun 22, 2009
Plumbing Forum, Professional & DIY Advice Repair of a Mansfield 500 outdoor faucet May 10, 2009
Plumbing Forum, Professional & DIY Advice Mansfield anti-syphon outdoor faucet. Apr 10, 2005
Plumbing Forum, Professional & DIY Advice Soldered Stem -Mansfield Frost-Proof Sill Cock Jun 23, 2016
Plumbing Forum, Professional & DIY Advice Mansfield Anti-Siphon Wall Hydrant Leaking in Wall Mar 19, 2015
