Mansfield low boy toilet
Discussion in 'Toilet Forum discussions' started by rniner, Mar 8, 2009.
  1. rniner
    rniner New Member
    Mar 8, 2009
    I have a 1977 Mansfield one piece low boy toilet #11631 sold under Montgomery Ward name. It has an Indiana Brass 79 E fill valve. Not sure who makes the flush valve. It is brass with an angled seat and attaches from inside the tank. I use a Radiator specialty #264 flapper. After a few years the rubber gets a black film on it and has to be replaced. I replaced with a a spare Radiator flapper and it did not work. Went out and bought a new one thinking my spare had aged and it did not work. I steel wooled the brass lip of the flush valve thinking that it must have a nick or crud. No effect. Can't get flush valve out to inspect closer. I thought it could be rubber gasket under flush valve, but if it is the water stays in the tank until above the rubber gasket under the flush valve. But that seems like my only solution at this point. The problem is what flush valve replace it with ( Rember tank water depth is only 4 inches) ?
    (This is an old house. When I bought the house it took me awhile to figure out only a Radiator specialty#264 would work. There is only one store I know that carries it. It has to very soft as there is not alot of water pressure to seal it. The flapper needs to float well because it's a low boy. The nose into the valve has to be short or it interferes with the valve. The reach has to be right because the valve has its own brass pegs that interfere with any other method of attaching. Replacing the toilet is also difficult. It needs to be under 22" tall and it has 14 inch rough in. )
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Ideally, you should get a new toilet. The real limiting factor is the low height requirement. I know of no toilet that would be that low. Most toilets rely on gravity to give force to the the water and this is achieved by height of water in the tank. The 14" rough in is not ideal but not that limiting. Would it be reasonable possible to change the conditions that limit the height? Of course, all things are possible if your pockets are deep enough:D
  4. Terry
    Aug 17, 2004
    Can you post some pictures of the inside of the tank?
    14" rough isn't a problem. Any 12" would work.
    The height is a problem.
  5. rniner
    rniner New Member
    Mar 8, 2009
    Any suggestions? Thanks.
Similar Threads: Mansfield toilet
Toilet Forum discussions A close look at the Mansfield Cascade rimless toilet -PICS- Jan 8, 2013
Toilet Forum discussions Has anyone seen this relativity new Mansfield rimless toilet? Nov 18, 2012
Toilet Forum discussions Mansfield 1983 Toilet: Tank to Bowl Gasket Nightmare Jun 14, 2011
Toilet Forum discussions Need help choosing a Toto..or Mansfield toilet May 18, 2011
Toilet Forum discussions Mansfield toilet overflows Nov 22, 2010
