Mansfield 211 Flush Valve
Discussion in 'Toilet Forum discussions' started by kurkevan, Sep 22, 2011.
  1. kurkevan
    kurkevan New Member
    Sep 22, 2011
    NJ
    Hi all,
    I have a really old Mansfield toilet whose flush valve needs to be replaced. After some research, I decided to purchase the 211 model, since it is the most economical (1.5 gpf). However, now I am worried that the bowl was not designed for such low volume, and perhaps it will not flush properly. Is this a concern at all? Thanks!
  2. jadnashua
    Back when they started to require lower flow toilets, the manufacturers tried just that...lowering the water used during a flush. It didn't work. Those years of poorly performing toilets gave low-flow a bad name. Do yourself a favor and get a new one that will actually work.
  4. kurkevan
    kurkevan New Member
    Sep 22, 2011
    NJ
    Yikes. You don't think it's even worth a try? The other model (210) uses more than double the amount of water.
  5. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    The Mansfield is a very low quality toilet and nothing you can add or do to it will change that. The leader in low flow toilets today is Toto. It would do you well to go to the top of this page and click on "Toilet Reviews". Then select "Shopping", and finally "Toto". Here you will find all of the models Toto makes including the prices that Terry Love sells them for in Seattle. While no one sell MSRP, prices may vary in your area. Consider this a lifetime purchase. The Eco Drake uses only 1.28 gallon per flush.
  6. kurkevan
    kurkevan New Member
    Sep 22, 2011
    NJ
    If I were replacing the toilet, I would definitely look into buying the ones you mentioned. But as of now I am just replacing the flush valve, and would like to know in advance whether the 1.5gpf will do the job, or if I need the 3.5gpf valve.
  7. Terry
    Aug 17, 2004
    No.
    If you have a 3.5 toilet, then using 1.5 will only stir the water, not flush it down the drain.
    Just pick up the 3.5 gallon flush valve.
    If you want to save water, you will need to replace the bowl.
Similar Threads: Mansfield Flush
Toilet Forum discussions Mansfield 208 flush valve seal...replace or upgrade Jan 28, 2013
Toilet Forum discussions Sticky Mansfield 160 Flush Valves Dec 29, 2012
Toilet Forum discussions Replaced old Mansfield flush valve seal, but still have trickling leak... Mar 17, 2012
Toilet Forum discussions mansfield 35 flush valve or seal leak Oct 27, 2011
Toilet Forum discussions Replacement parts for Mansfield Water Saver flush valve. Apr 21, 2011
