Manifold sizing to main pex line
Discussion in 'Boiler Forum' started by wayno12, Sep 22, 2010.
  1. wayno12
    wayno12 New Member
    Sep 22, 2010
    Michigan
    Hello everyone. This site is a world of information, but I need some help. I am planning the installation of a outdoor wood boiler, and the salesman is telling me to run a 1" main line 85' from the outdoor stove to a 1 1/4" manifold in the house. This manifold will feed 1" line to a water to water hot water heater then continue on to a 185K BTU water to air exchanger. Second, a 1" line will run from the manifold 104' to a small bunkhouse which will heat 2 rooms 600 sq ft. each, using 2- 11K BTU wall mounted fan assisted water to air heaters, plus another water to water exchanger for the water heater in the bunk house. A 3rd 1" line will come off the manifold and go to a water to water heat exchanger for a swimming pool 90' feet away from the manifold. The swimming pool heater will not be operated along with the other system except for maybe in the late spring at pool start up, and fall near pool closing. I am looking at a Central Boiler E-Classic 2400 as my heat source. Does this sound like a reasonable setup as far as trunk lines (I think that's what the main lines are called) are concerned and the manifold is concerned? Will 1" main line from the boiler supply enough volume for two or three 1" lines branching off this 1 1/4" manifold in the way I have described? And finally, is a 1 1/4" manifold necessary since main line in is only 1" and all lines exiting the manifold are 1"? Any help at all would be tremendously appreciated!
  2. peter_
    peter_ New Member
    Oct 16, 2010
    NYC, US
Similar Threads: Manifold sizing
Boiler Forum Help choosing a control system and manifolds for Hydronic Heating Jan 8, 2014
Boiler Forum Another boiler sizing question. Dec 27, 2016
Boiler Forum Over sizing a HTP UFT boiler in anticipation of basement remodel? Nov 1, 2016
Boiler Forum (Yet another) Boiler Sizing Question Sep 11, 2016
Boiler Forum Radiator Sizing Feb 26, 2016
