manifold diagnostics
Bob Gyngard
Beaumont, CA
The sprinkler manifold will not come on when electrically activated, only when manually activated at the valves screw or knob whatever you call it. I have replaced the solenoid and no difference. Does this mean the valve is broken? It is not the connection at the sprinkler timer box.
Mike1059
irrigation tech.
Portland, OR
www.mrhirrigation.com
The first question is it a single valve that is the problem or all the valves at the manifold. I it is a single valve then it's probably a broken or bad connected station wire. If it's more than one valve it's probably the common wire but the trouble is the wiring.
